跳转到主内容
加入维修社区 - 创建账户
Asus Padfone 2 于 2012 年 10 月 16 日发布,是 Asus Padfone 的继任机型。
Dust on back camera
HI, i'm a proud padfon 2 owner, but after few months of use, I notice some dust on my back camera...wow!!!It's terrible!
Can you post a guide on how to clean the back camera?How can I try to do it?thank you.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
3个答案
已选择的解决方案
Hi! Just go to step 5 in this guide, without disconnecting the battery. Asus Padfone 2 屏幕更换
这个答案有帮助吗?
得分 0
2条评论:
Hi! The protective camera lens just lays on top of the camera, so lay it back. Will make a guide sunday evening anyways! :)
由完成的
Im looking into a sultion using Photo-album-sticky stuff. Replacing my screen as soon as i get it, will try it then, and make a guide! :)
由完成的
添加一条评论
I have the same problem, a guide would be nice :-)
这个答案有帮助吗?
得分 0
2条评论:
Jonatan:
Well, I can see the Camera, but it also states that "Note that the protective camera lens will get loose!"
Right, I am not a technical genius, but how do I fasten the Protective camera lens again?
由完成的
Hi Jonatan
Do you have any good ideas how to prevent dust in the future?
Is it possible to seal it somehow?
由完成的
添加一条评论
To stop dust getting in, jam "something" in the headphone jack. I found that cutting an old headphone plug off ( the part you put in the jack ), and then inserting it in backwards ( ie rubber bit in 1st ) and then cutting the rest down to an appropriate size works well. There are apparently plugs you can buy, but I can't find any locally. I guess you could also use bluetack or chewing gum or something :P
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Defteros 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 11
总计 4,224
