跳转到主内容
The Kodak EasyShare C913 is a 9.2 MP digital camera.
10 个问题 查看全部
Replace battery cover on Kodak C913
I have purchased a new cover for the battery compartment for my Kodak C913. I can't figure out how to take off the broken one to replace it. I'm afraid of breaking more of the plastic if I force something.
Thanks you
Pauline
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Pauline, take a look at this guide. Once you remove the case, you can see the pin that holds the battery door in place. Make note of how the spring attaches, take pictures :-) remove the pin with a paper clip or other small instrument and replace the door. Hope this helps, good luck.
这个答案有帮助吗?
得分 1
添加一条评论
Hi! I am having no luck getting the batttery cover open. It is stuck tight, or I’m just not smart enough to figure out how it works. I did take the back cover off, and can see the pin that holds it on, but have no idea how to get it out of there to get the cover off. It looks like the cover needs to slide some to release the latch, but I can’t get it to slide at all.
Can you help?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Pauline 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 1,147
