跳转到主内容
Kodak EasyShare C913 Capacitor Replacement
你所需要的
  1. Kodak EasyShare C913 Capacitor Replacement, Batteries: 步骤 1 中的图像 1,3 Kodak EasyShare C913 Capacitor Replacement, Batteries: 步骤 1 中的图像 2,3 Kodak EasyShare C913 Capacitor Replacement, Batteries: 步骤 1 中的图像 3,3
    • Position the camera with the bottom facing up.
    • Slide the battery cover in the direction of the arrow with your finger gently.
    • Remove the batteries
  2. Kodak EasyShare C913 Capacitor Replacement, Back Case: 步骤 2 中的图像 1,3 Kodak EasyShare C913 Capacitor Replacement, Back Case: 步骤 2 中的图像 2,3 Kodak EasyShare C913 Capacitor Replacement, Back Case: 步骤 2 中的图像 3,3
    • Remove the seven 4.5mm screws with a Phillips #00 screwdriver.
    • 2 on the left
    • 2 on the right
    • 3 on the bottom
  3. Kodak EasyShare C913 Capacitor Replacement: 步骤 3 中的图像 1,3 Kodak EasyShare C913 Capacitor Replacement: 步骤 3 中的图像 2,3 Kodak EasyShare C913 Capacitor Replacement: 步骤 3 中的图像 3,3
    • Firmly grasp the back of the camera and pull the away the casing.
  4. Kodak EasyShare C913 Capacitor Replacement, Front Case: 步骤 4 中的图像 1,3 Kodak EasyShare C913 Capacitor Replacement, Front Case: 步骤 4 中的图像 2,3 Kodak EasyShare C913 Capacitor Replacement, Front Case: 步骤 4 中的图像 3,3
    • Keep the battery door open
    • Firmly grasp the front casing and pull away from the camera.
  5. Kodak EasyShare C913 Capacitor Replacement, Capacitor: 步骤 5 中的图像 1,2 Kodak EasyShare C913 Capacitor Replacement, Capacitor: 步骤 5 中的图像 2,2
    • Orient the camera with the lens facing you.
    • Use a Phillips #00 screwdriver to remove the one 2.2mm screw on the plastic bridge.
    • Lift the plastic bridge off and place it to the side.
  6. Kodak EasyShare C913 Capacitor Replacement: 步骤 6 中的图像 1,1
    • Do not touch the capacitor contact points for any reason. This will result in a severe shock.
  7. Kodak EasyShare C913 Capacitor Replacement: 步骤 7 中的图像 1,3 Kodak EasyShare C913 Capacitor Replacement: 步骤 7 中的图像 2,3 Kodak EasyShare C913 Capacitor Replacement: 步骤 7 中的图像 3,3
    • Grasp the capacitor, carefully remove it from its holder, and place it off to the side.
  8. Kodak EasyShare C913 Capacitor Replacement: 步骤 8 中的图像 1,1
    • De-solder the connections at the base of the capacitor
结论
Alan Galarza
于10/03/10注册
81 声望
创作了3篇指南
团队
Cal Poly, Team 7-51, Amido Fall 2010 Cal Poly, Team 7-51, Amido Fall 2010 的会员
CPSU-AMIDO-F10S7G51
4 名成员
创作了14篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 42
总计 4,201
