跳转到主内容
型号A1367,闪存容量:8、16、32及64GB
My screen doesn't work when I touch it
I dropped my iPod through a hole in my jacket and now when i touch the screen nothing happens. at first only the sides where doing this but now the whole screen is like this. What do i do? Can it be fixed?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
3个答案
最有帮助的答案
Jovan Joiner, since you mentioned that " only the sides where doing this " I would assume that your digitizer circuit has failed. You will have to replace the front assembly. Here is the guide for it and the part is available right here as well as many other places. Of course you also want to make sure that it is properly connected and the the connector as well as the logic board are properly seated. Ultimately I think that it is your digitizer. Hope this helps, good luck.
Replace a front glass screen digitizer compatible with the fourth generation iPod Touch model A1367.图片
产品
iPod touch (4th Gen) Screen
$29.99
这个答案有帮助吗?
得分 1
1条评论:
my ipod 4g at first was fine but I dropped it and the bottom left of the screen cracked :(. But I would have to slide at the top on the ipod and that's how I would unlock it but now it wont work.... what do I do :(
完成的
添加一条评论
i dunno the same thing has happen to mine 2nd generation.I dont know why but the battery was dead and i put it on charge and it does not work.it happen 2 times already.Now is the 3rd time PLZ HELP;(
这个答案有帮助吗?
得分 0
添加一条评论
Try Holding power and home it worked for me
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jovan Joiner 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 5,678
