跳转到主内容
加入维修社区 - 创建账户
MacBook 维修指南。苹果公司于 2019 年 7 月 9 日停止生产该系列。
Problem Topcase - Keyboard and Trackpad not working
Hi all,
I have a white macbook A1181.
It is a 2,4Ghz Core 2 Duo.
I have a problem with my topcase.
I tried a lot of things already, but then I do not know.
He was no longer detected. I replaced it and same result.
I cleaned the connector with alcohol with a brush ... But nothing was done.
I redid the solder points of the connector and now it works!
But only 1 minutes or 2 ... After it stops functioning without doing anything ...
I do not really know what to do ..
Any ideas?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
4条评论
Will an external keyboard and mouse work?
由完成的
Thank you for the interest you have shown in my problem!
There is no liquid was poured on.
I'll do the test with USB keyboard / mouse in the day ...
I come to you with the result
由完成的
ok, if I connect a keyboard and a mouse that works perfectly ...!
由完成的
there's any alternative points where I could solder the pins of connectors?
由完成的
添加一条评论
4个答案
已选择的解决方案
My guess is that it's not the keyboard or trackpad that is physically damaged, but rather the connections from those to your logic board. If you resoldered it and it worked for a minute then you're on a good lead. Try redoing the solder very carefully, and make sure it's impeccable. Then try that. If that doesn't work, look at other points along the connection cable, including where it meets both sides.
这个答案有帮助吗?
得分 2
2条评论:
yes, the problem is really weird!
Because every startup without touching anything at all it works again 1 or 2 minutes.
In parallel if a mouse is plugged in via USB, when the trackpad stops functioning mouse it run continuously all the time!!
I tried with other topcase and the result is the same.
I've already redone a lot of spot weld...
由完成的
So if you've swapped out the top with another one and they both have the same problem, it's probably the MacBook side that's faulty here.
I'm not sure if Apple does this, but you could try updating the "BIOS" equivalent, but probably call it "firmware" or something. I'd research it for you if I had the time, but you can probably find what you're looking for. So try to find a firmware update for your MacBook, and maybe that'll help with your problem.
由完成的
添加一条评论
最有帮助的答案
Sounds like liquid damage (top case problems and sudden quitting). Follow the tags on the right for more advice/steps to take in diagnosing & reviving the logic board.
If this Answer is helpful please remember to return and mark it Accepted.
这个答案有帮助吗?
得分 2
1条评论:
I looking on google the BIOS but I can not find anything...
由完成的
添加一条评论
Recently I refurbished a Macbook A1181 (version 4.1 , the one @2.4Ghz) and I had the same issue.
When I finished the repair and mounted the keyboard and trackpad back on, as well as the battery, I realized they where not responsive, despite the power button still worked.
I read in a forum there was an issue with this particular model and the ground level, making that both the keyboard and the trackpad don't work.
What I did was sticking a tiny little piece of a plastic sheet between the metal case and a little gold V-shaped connector that is spotted in the left side of the battery connector board (if you watch it from the pins side), to avoid contact between them. This worked for me.
Hope this helps.
这个答案有帮助吗?
得分 1
1条评论:
I have three keyboards here with the same problem, I can't believe it's a hardware problem where exact I should place the plastic sheet for avoid ground level?
由完成的
添加一条评论
I had a similar problem was solved by replacing the trackpad and cable.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Eldoctor62 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 18
总计 2,970
