跳转到主内容
The Apple TV is a digital media receiver designed by Apple and released on March 21, 2007
17 个问题 查看全部
问题已关闭
status light does not work
Apple TV 1st Generation YM04728DYR4, the device works properly with the paired remote. But the status light does not light up at all under any circumstance.
The deice stays hot but I do not find a way to turn it off or on. It always seems to be on. IS THERE A WAY TO TURN IT OFF?
thanks for your help.
James cowley
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
james cowley, there is no real way to turn it Off. Press and hold Select for five seconds (or go to Settings > Sleep Now on Apple TV (2nd generation) or Settings > Standby on Apple TV (1st generation) Apparently the 1st generation does get fairly hot since it uses part of the body as a heat sink. for as long as it does not power down due to the heat, I would not worry to much about it. there are discussions on different forums about different rubber feet as well as converting to SSD with no real results about the heat. As for your LED Staus light, check this answer.
这个答案有帮助吗?
得分 1
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 955
