跳转到主内容
Status LED burned out, need to replace it.
Hi,
Here, where I live, Apple doesn't sell or repair Apple TVs, but I bought one in a recent trip to USA.
The Status LED burned out and now I will have to replace it by myself.
Do I need to do all the steps in the Apple TV 2nd generation teardown guide to replace it or could I skip some steps?
Best regards,
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
I suggest you just leave as it is since it's only as you say, a status LED, meaning it doesn't interfere with the device's main purpose. Other thing. LED's don't burn often, so the problem could lie somewhere else. Thus my response. Hope it helps.
完成的
添加一条评论
1个答案
已选择的解决方案
You will need to remove the logicboard for the repair. Here is a guide to to that. I must warn you it possibly might not be just the LED. LEDs only function properly with a driver chip and series resistor. They tend to burn out quickly with out these items. All of these items could be bad since it stopped functioning. To test if LCD that is bad, measure the voltage drop across it's pins if it is approximately 2 volts or more, the LED is likely all that is bad.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Zillo 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 4
总计 2,556
