跳转到主内容
Procedure on how to clean the Logic Board with isopropyl alcohol?
I have a MacBook Pro 13 2011, how I proceed with cleaning the logic board which was subject to water damage?
And how do you precede with cleaning? Using cloth or how?
Saw a topic on this page Cleaning a logic board......
Thank you
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
3个答案
已选择的解决方案
Here's the guide for doing this: Electronics Water Damage
这个答案有帮助吗?
得分 2
添加一条评论
Aslamualikum dear brother i used mother bord cliner fine product
这个答案有帮助吗?
得分 0
1条评论:
Hello Brother can you pls help,need advice
完成的
添加一条评论
Genius Guy, recommend you first open your system and get 99% alcohol to clean the board, dont be scare to take a pane with alcohol and clean the board using a tooth brush getting wet the board it will be ok for Apple boards but not for pcs, leave it for 20 mins, alcohol is acting under chips, then blow it up with regular compressed air, if you are in a hurry blow it up after with hot air, make sure you dont create static electricity, then wait for one hour inspect board again before turn the computer on again.
这个答案有帮助吗?
得分 0
1条评论:
HI need help , i spill hot milk in to mother board , if i clean as u said its will work and won't damage the board.
完成的
添加一条评论
添加你的答案
Martins Strobinders 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 13
总计 30,348
