跳转到主内容
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
Dimmed backlight display on external and internal LCD
Hello Guys , on external disp which thers no signal completely not responsive -no image at all
and the internal lcd is dimmed
i guess it might be the inverter or the power cable of it
perheps??????any idea?
the cable which is used is hdmi converter from display port to the external display and the inner lcd is dimmed
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Is the external a monitor? If so see if you can test this hook up on another machine to make sure it is working properly. I ask you to do this because your results are not consistent. You should either have no screen on both (GPU issue), or a good external and bad internal. You should not have a bad external and still be able to see the screen.
这个答案有帮助吗?
得分 3
5条评论:
Dearest MAYER please help me if you can i will apprichiate it more then you realiz.
the external monitor works fine now and works constantly! ! and suddenly the screen is showing signal when i moved it in surtain direction ,when i EVEN A BIT move it the internal lcd will lose signal !!
what can it be ? WHILE THE INTERNAL LCD worked i tested the inverter and tried to change brightness-NO PROBLOM WITH THAT!
WHAT CAN IT BE?
might it be the cable of the power to the inverter? and where the inverter cable (not the power cable f it ) connects to the logic board?
i am realy carefull opening it since the macbook late 2008 has bad flat(flex) cable of the top assembl(touchpad and keyboard) so i wouldnt want to open it a lot more
waiting for you advice..........
完成的
can it also be the lvds cable tough when i opened it it seemed real fine!it does not sound logic to be an lcd issue! BUT WHIch one?
i suspect the cable
完成的
Now that you have confirmed the external monitor (this rules out the GPU), your suspect is the display data cable. It would help to know exactly which machine you have to if it even has an inverter cable. Please give us the last three figures of your serial number.
完成的
thank you,the last serial numbers are 0P2 model :a1181 black
From what i ahve understand ihas an inverter and surely has a power cable -"for the inverted| connected to it ..maybe.......
完成的
Apple MacBook "Core 2 Duo" 2.4 13" (Black-08) Specs
Identifiers: Early 2008 - MB404LL/A - MacBook4,1 - A1181 - 2242
I would replace both the inverter and inverter cable. Here's how: MacBook Core 2 Duo Inverter Replacement
完成的
添加一条评论
添加你的答案
MASTA KAHUNA 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 446
