跳转到主内容
加入维修社区 - 创建账户
一款 HP 于 2011 年推出的平板电脑,运行 webOS 平台。配备 9.7 英寸显示屏,提供 16 GB 或 32 GB 版本。维修过程直观,但需要时间和耐心。
Battery Icon with question mark (?)
My HP touchpad is out of warranty. When I try to power it on it shows a battery icon with question mark in it. When it is connected to a charger the light flashes on the center button. I have tried all solutions posted on the web, with different button combinations, leaving it on charge for more than a day, using different cables, trying to leave it connected to a computer, etc. Everything brings back the battery icon with question mark and cannot do anything more.
Connecting to a computer with USB, makes the center button lights to flash, but cannot access the file system thru USB.
I thought changing the battery, but not sure if that will fix the issue.
Is there a way to reset to factory defaults?
Please let me know if there is anyway to fix this.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
7个答案
已选择的解决方案
Here's how to replace your DEAD battery: HP TouchPad 电池更换
这个答案有帮助吗?
得分 6
添加一条评论
It is more than likely not the battery, but that it is 'bricked' due to corruption of the boot-up firmware. Many people have had the issue, including myself, and resolved it by the methods at this link:
http://rootzwiki.com/topic/38786-tpdebri...
If this works for you, then thank all the people who worked to develop a solution especially 'jcsullins'!
这个答案有帮助吗?
得分 2
添加一条评论
In french the solution is here:
http://lmorel3.fr/2014/05/debrickez-votr...
这个答案有帮助吗?
得分 2
添加一条评论
my talet still has a question mark on the energy symbol i try all the website in the whole world i think.but It did'nt work. i try to charge It on the computer It did'nt work, i bought a new charger It still did'nt work. now i'm just bored at home
这个答案有帮助吗?
得分 1
1条评论:
IF you are bored, you should get a new iPad.
由完成的
添加一条评论
Resolve this issue...
这个答案有帮助吗?
得分 0
添加一条评论
Hello I got a LG phone and when I turned on I saw the question mark on the battery I plugged In for a hour I stayed off it I plugged in for the whole night WHAT SHOULD DO????
这个答案有帮助吗?
得分 0
1条评论:
did you ever figure this out? i have same problem email me skram84@gmail.com
由完成的
添加一条评论
My new stylo 5 phone has its original charger it shows a question mark when plugged in. What can I do to fix it?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Rani 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 14
过去 30 天: 41
总计 47,224
