跳转到主内容
加入维修社区 - 创建账户
The PowerShot SD1000 Digital Elph is a digital camera with a 7.1 Megapixel a 3x optical zoom
"No Memory Card Error" What next?
Hello Everyone. I am new here so bare with me.
I tried all the "WONDERFUL' toothpick tricks and what not, to no avail. I still do not have successful results.
I disassembled the camera completely.
I am attaching some pictures to see if anyone sees something that I am missing. Something I am overlooking. Also, is there an option to fix the memory card slot…ie. Soldering or replacing it?
Your comments are welcomed and appreciated
Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
I assume that you originally tried more than one card, just to rule that out as the cause. You can replace the card reader, as long as you find a proper replacement. This one should be a standard one, so I would try to scrounge a broken camera and replace it. the soldering will be somewhat tricky and will require a bit of practice :-) but it can be done.
完成的
添加一条评论
2个答案
已选择的解决方案
One of the contact pins are probably bent or mashed in.
The way SD card slots are soldered to the PCB makes it nearly impossible to replace. Machines, not man solders this stuff together when it's made.
Your best bet is to get a good main PCB from a junker SD1000 camera on eBay.
这个答案有帮助吗?
得分 1
1条评论:
Thank you very much for responding.
I went ahead and purchased a new PCB on Ebay.
I really wanted to try to replace the memory card slot but as you said, it can be really tricky and besides, I did not have the correct solder pin.
完成的
添加一条评论
Mission Accomplished.
What shall I get myself into next?
这个答案有帮助吗?
得分 1
2条评论:
Excellent, great job.
完成的
Thank you very much. It was interesting.
完成的
添加一条评论
添加你的答案
Janet 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 33
总计 2,600
