How much charging time does it need
for how long does it take my ipon shuffle to fully charge.
Apple says "A depleted battery can be 80-percent charged in about two hours and fully charged in about four hours."
Source: http://manuals.info.apple.com/en/ipod_sh... page 6
这个答案有帮助吗?
So, the first 80% takes 2 hours and the last 20% takes 2 hours. Weird.
You can usually check what kind of charge your iPod has from looking at the colour of the light when you turn it on. Yellow is medium charge, green is fully charged I think whereas red is almost 'flat'. It tells you about this in the little book that comes in the box, if that helps.
这个答案有帮助吗?
it takes about 1 and a half hours
Hi, IPOD 1gb was kept on for many days as i am not able listen or change / shares songs in it or with my computer. Kindy help me out.
这个答案有帮助吗?
So it is not working anymore because the battery is empty? Or it is not recognized by iTunes? Give us a little bit more information please. What are your symptoms?
mine got the same problem after using for long with my dvd, now i cant sync new music to it, and it doesnt want to restore. it says connect to internet wherever i want to restore it.
If you haven’t used it from a long time you..... it will be probably discharged..... you can charge it with the charger with that 3.5mm audio jack, and it would work after the battery is charged.... To check you can charge the same for 15-20 min to check wether it’s playing or not.... plus when you’ll pit it on charge it will blink orange light and it will turn to green when fully charged!
If then also it doesn’t work but I tunes recognise it then restore or factory reset it it’ll take a min or two and you are ready to go to load songs
ipod suffel needs only 20 mins for full charge. because after that much charge i use it for 10 days in my jogging.. i love it
这个答案有帮助吗?
my i pod shuffle is only 8 months old and i get 2 hours of playtime when fully charged. This doesn't seem like a very long time. Can anyone tell why this is?
这个答案有帮助吗?
You may have charged via bad charger. Coz i am using it about a year and its working fantastic. Gives battry life of abt 12-14hrs
gwejfsenjfnesjangjawnghwgwhgjwhgehgherghghrghr
Charging Indicators when listening to iPod shuffle
Status Light Charge Level Audible Notification1
Green 76% - 100% “Battery Full”
51% - 75% “Battery 75%”
26% - 50% “Battery 50%”
Orange 11% - 25% “Battery 25%”
Red 1%-10% “Battery Low”
Blinking Red <1% Tri-Tone
None2 0% None
hope this will help us...
这个答案有帮助吗?
Should there be a light while charging??
Same question.It blinks 4 times then stops.Also will only charge if I do a restore first.I have another shuffle that also needs restore before it wil charge.?
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 31
总计 40,555
3条评论
I noticed you never got an answer to this. Are you still having this problem?
由 originalmachead 完成的 分享
https://www.reddit.com/4bajzz/
https://www.reddit.com/4bak66/
https://www.reddit.com/4bakdm/
由 kurikong 完成的 分享
My iPod shuffle A 1204(emc2125) had problem. Charging time it shows yellow and green both colors. Then it not be playing also send me the solution
由 kunju dude 完成的 分享
