跳转到主内容
The eighth generation of the Mitsubishi Lancer.
20 个问题 查看全部
engine management light is on, having loss of power
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
stephanie, the first thing you should consider , is to have any error the codes pulled of your computer. Places like Autozone can do it for free. See what you get. The other things that could cause this, including the power lossm could be carbon buildup in your throttle body, including the EGR valve as well as the MAF sensor. You did not tell us how handy you are, but a good cleaning of the air intake components may be a great start. Hope this helps, good luck.
这个答案有帮助吗?
得分 1
添加一条评论
Another cause of this could be a Coil-on-Pack going bad. The Lancer uses a distributor-less system to send electricity to the spark plugs. There are two coil-on-packs above the 2nd and 4th spark plugs on top of the motor, each controlling 2 spark plugs. If one of those goes or is starting to go bad, you'll get an engine code, loss of power, and the engine will idle roughly, since it's only firing on 2 cylinders instead of all 4. They're about 90 bucks at an auto parts store, and only take a few minutes to replace. At the same time, I'd replace all the spark plug wires, and the set of spark plugs. The Lancer uses NGK Iridium plugs as OEM, I would definitely replace with those, as the copper or platinum plugs will give you a rough idle and power loss as well. All in all you can replace these in about 15-20 minutes with a 3/8" ratchet, extension bar, spark plug socket, and a 10mm socket.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
stephanie 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 2,925
