跳转到主内容
加入维修社区 - 创建账户
The Panasonic Lumix DMC-TZ5 was released March, 2008. It is the third camera in the TZ series, with a 3.0 inch viewing screen, 28-280 lens (10x optical zoom) and 9.1 megapixels. The TZ5 also has 720p HD video recording.
Motion recording cancelled due to writing speed of card
Since not long ago, I face a problem with the recording. I record videos that contain or not action scenes and the recording stops (e.g. after 20 sec.) with the message « Motion recording was cancelled due to the limitation of writing speed of the card ». I don't understand why it worked in the past and that the problem started many videos after starting using a very good card (SanDisk Extreme HD Video, 30 Mb/s; 16 Gb). Can this problem be fix?
Thanks,
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
Have you tried a different card? I am a bit confused. This error started when you started using the SanDisk or it happened before with another card as well?
完成的
Hi Eric, I have the exact same problem! LUMIX G7 4K, I have been using it with an 8gig 4speed Kingston card absolutely fine, But I need more space to film in 4k so I got a SanDisk 32g class 10 and it keeps canceling recordibg due to speed of card.
If you found a fix please post for me. Thanks mate.
J
完成的
添加一条评论
5个答案
Eric, it is possible that your camera is having with the Speed Class 10. You may need a firmware update. I would suggest you try either a class 3 or a class 6 card and see if that will work. Here is a bit more information I found about your card "The limitation of this card is that it normally operates at 20MB/s and only achieves 30MB/s in the few devices that support UHS-I. If your device doesn't specifically state "UHS-I", try a more "normal" version. This is based on research and responses from SanDisk. Hope this helps, good luck.
这个答案有帮助吗?
得分 0
添加一条评论
If you switch your video recording mode off of 4k to regular HD it works smoothly... with no cancellation.
这个答案有帮助吗?
得分 0
添加一条评论
You just need a faster sd card because lumix cameras film at 100mbs
这个答案有帮助吗?
得分 0
1条评论:
If you switch from 4k 30p to 4k 24p in your Rec quality setting that should fix the issue.
完成的
添加一条评论
This happened to me as well with a card that I know is fast enough for the G7. I had used it in the past and everything had been fine but one day I ran into this problem and have been looking for a solution. I am going to try to format my SD card in ExFat to see if that will fix my problem.
这个答案有帮助吗?
得分 0
1条评论:
It's probably worth mentioning that I have another SD card that doesn't have this issue
完成的
添加一条评论
i have this message come up after formatting my SD card now i don’t know what to do as it worked fine before. Is there a possible way to format the SD card back?
这个答案有帮助吗?
得分 0
1条评论:
I would just buy a new memory card with a higher recording speed. I had a 60MB memory card and I switched to a 90MB and it doesn't show up anymore. Tell me if it works!
完成的
添加一条评论
添加你的答案
Eric 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 30
总计 11,243
