跳转到主内容
Model A1311 / Late 2009 / 3.06 or 3.33 GHz Core 2 Duo processor
310 个问题 查看全部
internal lcd connector to logic
have an iMac 21.5" the pins on lcd internal connector and removed some pins from the board while attempting to replace the hard drive. can someone help me?
already use machine to stuck them but nothing.. only some light on lcd when i power on the imac.. also if i use second screen is ok.. i will post some photos to see..
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
4条评论
You broke pins off the logic board?
完成的
So did you find someone to fix this for you? If so, who was it and how much did they charge?
Thank you!
完成的
Just an FYI, the connector is an I-pex 20455-030E readily available for around $5.00 USD
完成的
hi,
i worked by Apple a few years ago and i have the skill to fix it ...
thanks to take contact direclty with me on moja-me@hotmail.com
have a nice day
完成的
添加一条评论
2个答案
已选择的解决方案
Ouch!
Looks like you pulled off the header plate from the main logic board with a few pins broken off with it. Not much you can do here on your own. The logic board will need to be fixed if it can be. Often the traces get damaged when you tear off a component/connector like this.
If you can find someone with the correct skills and parts they maybe able to put a new connector on to the logic board (you take the risk of it not working after it's fixed $$). Otherwise, you'll need to look for a logic board to swap out.
In either case it will be expensive. Given the age of the system you might want to think about getting a new system Vs fixing this one, and selling this system for parts. Chalk it up to as a learning experience - Sorry ;-{
这个答案有帮助吗?
得分 2
添加一条评论
This sort of repair is not a DIY project. An electronics shop might take it on, they would have the tools and experience required.
If this answer was helpful please remember to mark it accepted.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Valantis 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 2,175
