跳转到主内容
Released by Nokia in May 2009, the Nokia 6303 is designed mainly for voice calls, texting, and music playback.
resetting security code how
My keypad is locked with security code. I changed the security code. Now I can't open it. Either I forgot what code I entered or I pressed the wrong numbers and I didn't know. Now I can't unlock my phone. What can I do to solve this?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 29
4条评论
Tengo un telefono que me enviaron desde inglaterra y vivo en colombia como hago para el codigo de seguridad
完成的
nokia6303 secruty code
完成的
I keep receiving phone number. 6303036998032 ? my phone ia a Samsung ?
What is going on?
完成的
unlock my moile nokia 6303i
完成的
添加一条评论
3个答案
已选择的解决方案
What's your Mobile model?
Try default codes like 12345,00000.If your mobile is Nokia or Alcatel you easily reset your mobile by using Master Reset code.You can get the code from Unlock-Free.com at free of cost.Here they will generate you reset code within a minute by specifying your mobile model no and IMEI.
Note:They will provide reset codes for some basic Alcatel and Nokia mobile models only.
这个答案有帮助吗?
得分 2
3条评论:
Thank you you umblocked my password Im so stupid
完成的
cant find nokia 6303ci !
完成的
Hi security code for Nokia ta-1402 8 digits
完成的
添加一条评论
Kae, follow these instructions Hope this helps, good luck.
这个答案有帮助吗?
得分 1
3条评论:
Dead link. Was going to accept it, letting you know. I also got a redirect alert from AdGuard in Chrome, now the site will not load in Safari OR Chrome. Normally I'd try and find a working reference but with 2G being doomed globally I'm just going to "solve" this one by accepting @braksa's answer.
Likely blocked by the Mac AdGuard app. Not your fault the ownership changed, but I'm letting you know.
完成的
@nick 🤣you know it does not matter as long as something worked for the OP. It’s not about accepting but about getting in solved. Best answer is always the right answer 👍
完成的
@oldturkey03 it either redirects to a dead page or very suspicious links.
完成的
添加一条评论
i forget my nokia 6303ci password ,how to open it?
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Kae 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 46
总计 24,247
