跳转到主内容
加入维修社区 - 创建账户
投影仪的维修与拆解指南。
Projector won't switch on
The projector doesn't switch on. Had the power supply replaced a few months ago to solve this problem and it worked for a bit after that but it's given up again. Can anyone advise or provide a service manual?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
hello can you tell where i can find a power supply for my plc xp 57 which is the model above yours ,i think the same power supply will work ,i look all over the net and i can't find it,thanks in advance
由完成的 分享
epson eb-s03 projector have power suppy but can't turn on. when I plug power have a blue coler in button but can't turn on it
由完成的 分享
添加一条评论
3个答案
已选择的解决方案
David Hicks, I'd definitely check the power supply first. Of course, start with the fuse F601 and R661 on the logic board. BTW,here you go :-)
这个答案有帮助吗?
得分 3
5条评论:
Thank you. The manual shows where the components are on the circuit board but refers to the main service manual which, I assume, will show how to take things apart to get at the board! Can you provide that one too?
由完成的 分享
found the main service manual at http://diagramas.diagramasde.com/otros/P.... Typical: the power supply board is at the bottom and requires almost complete disassembly...
由完成的 分享
Of course, you did not expect anything easy and user friendly :-) BTW good find, I will delete my link ;-)
由完成的 分享
i guess not. since it's broken and the supplier's advice is to cut my losses and replace I've got nothing to lose by taking it apart... more in hope than expectation. Thank you for your help. oldturkey03.
由完成的 分享
That is where places like this one, ifixit, does come in handy. If we would listen to the resellers and suppliers, we would be throwing stuff out, just to turn around and spend some more money on new ones. I bet the repair for your projector will only cost a fraction of what a new one would be....best of luck to you and let us know how it is working out.
由完成的 分享
添加一条评论
i think the power ic..replace the power ic and then change the new power ic..
这个答案有帮助吗?
得分 0
添加一条评论
Check the connector between the lamp and the ballast for oxidation on the contacts
especially the end of the ballast cord with the connector the lamp plugs into and clean with abrasives.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
David Hicks 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 50
总计 38,091
