跳转到主内容
学生贡献的维基
此维基页面由我们教育项目的学生团队编写。
设备无法开机
播放器没有显示任何开机迹象
外部电源线断开或损坏
  • 检查电源插座以确保其通电。如有必要,请使用其他设备测试或检查其他插座。
  • 检查所有线缆是否连接妥当且没有损坏。如果线缆损坏,请根据需要进行更换。更换后检查电源指示灯是否亮起。
磁盘无法读取
磁盘已插入但无法播放
磁盘上有污渍或损坏
  • 尝试使用超细纤维布清洁,从中心向外缘径向擦拭
  • 使用另一张磁盘进行测试。如果可行,则说明原始磁盘有故障。
光驱损坏
无法进行无线联网
播放器无法访问互联网
WiFi 未正确设置
  • 确保你的无线网络在其他设备上工作正常,并已按照互联网服务提供商的规格进行设置
WiFi 模块损坏
  • 如果仅是无线接收器损坏,请尝试将网线插入播放器后面板上标注为“LAN”的接口。
  • 如果这仍无法提供互联网连接,请考虑更换 WiFi 模块,详见 Panasonic DMP-BD89 WiFi 板更换。
设备卡死
播放器已开机但无响应
需要重启
  • 拔下播放器上的所有线缆和 USB 设备
  • 拔下电源,等待 30 秒至 1 分钟,然后重新连接并开启播放器。
播放器在固件更新期间卡死
  • 拔下电源,等待 30 秒至 1 分钟,然后重新连接并开启播放器。确保播放器再次恢复响应。
  • 将播放器重置为 恢复出厂设置。
  • 完成首次设置,并配置网络连接
  • 在尝试访问任何网络服务或应用程序之前,请从菜单执行固件更新。
David Sun
于10/17/17注册
213 声望
创作了2篇指南
团队
4条评论
Unable to watch Youtube app. It was working perfectly until there was a power cut and when it was restored and I wanted to watch a program in Youtube, there was a message saying Internal Communication Error and something regarding “Opera.help” ?
The model of my panasonic blu ray is DMP BD89 which is not included in the list of panasonic devices that google decided to terminate its YouTube service .
I reset my device, wifi is perfectly working, I can enjoy netflix services but not Youtube.
Could you please help me with this issue?
Thank you.
lucia lucia - 回复 分享
Trying to turn on my DVD player and can hear a clicking sound but it's not powering on. Any ideas??
Jaye carah - 回复 分享
When I power on my player, it makes the transformer "whirr" noise, then motor spin, then it runs. I don't think the "click" sound is normal.
Jri-creator - 回复 分享
HEY! This is a message to people who have this player. Netflix has decided to discontinue it's support for the player on 10/16/2023. Netflix will no longer stream on the player, even though it may still access the servers and retrieve the data. Some people may have been pre-warned about this already, and may have been prepared for this. I don't know why Netflix decided to do this, possibly due to support for different things not available, but it used to work well up untill now. It is best that you sign out of Netflix, and use something else to stream Netflix on, like a Roku tv.
Jri-creator - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 46
总计 5,617
