跳转到主内容
Magic Bullet NutriBullet 的搅拌杯、盖子或底座是否在漏水?NutriBullet 搅拌机可能会遇到各种导致漏水的问题,其中许多都很容易解决。检查以下可能的原因,找出并解决问题。
萃取刀片未拧紧在盖子上
如果 NutriBullet 的盖子没有带着萃取刀片紧紧拧在搅拌杯上,搅拌机可能会漏水。请对照搅拌杯上的螺纹,检查萃取刀片是否已正确拧在杯盖上。如果搅拌杯无法正确拧紧,你可能需要去 NutriBullet 官网订购一个新杯子。据用户反映,也可以在二手商店、旧货店或类似 Craigslist 的网站上找到 NutriBullet 的替换杯。
搅拌杯未固定在动力底座中
如果 NutriBullet 的搅拌杯没有紧紧固定并锁入搅拌机的高扭矩动力底座中,搅拌机可能会漏水。动力底座上有三个槽口,与 NutriBullet 搅拌杯侧面的三个凸缘相匹配。在使用搅拌机之前,请确保这些槽口和凸缘已对齐并正确啮合。
萃取刀片上的橡胶密封圈破损或撕裂
NutriBullet 搅拌机的萃取刀片部件在刀片底部包含一个称为密封垫的橡胶密封圈。密封垫的设计目的是将萃取刀片固定在杯子上并防止泄漏。如果橡胶密封垫破损或撕裂,搅拌机可能会漏水。请按照本 密封垫更换指南 来更换漏水的密封垫。
搅拌机内部或外部零件出现裂纹
NutriBullet 搅拌机内部或外部零件上的裂纹会导致漏水。裂纹还可能暴露布线和快速旋转的部件,从而导致其损坏。将搅拌杯从高扭矩动力底座上拆下,并检查 NutriBullet 动力底座的所有零件,寻找是否有裂纹。如果在底座上发现裂纹,请使用本 Magic Bullet NutriBullet 底座更换指南 来更换损坏的动力底座。如果是在 NutriBullet 搅拌机的杯子或盖子上发现裂纹,请在 NutriBullet 官网购买替换零件。
其他人对此提出的问题
相关页面
Arielle Sampson
于07/05/20注册
17,131 声望
撰写一个指南
7条评论
I’m wondering if shipping may have something to do with the Nutribullet Rx leaking. Remember the old TV commercials where the gorilla is throwing luggage around? That what the box looked like on my order. Several areas on the box were taped up with a substantial amount of tape. I took photos of the box.
if I can’t get any help from customer service, I’ll be returning the unit to Amazon.
Sherman Brown - 回复 分享
My Nutribullet coffeemake is leaking when I use the pod feature. It spews water/coffee
Sylvia Buice - 回复 分享
I bought a new magic bullet blender that leaks oil into the container, that mixes with the food. I just discovered it when i was blending papaya that turned dark gray. Prior to that, i was blending lentils with it to feed my baby. So i possibly fed my baby with lentils with machine oil from the blender
TravelingWolf - 回复 分享
Same here! I'll see if there is remediation for this issue.
joerogerio - 回复 分享
It might be the problem with a bearing that is placed under the blades. I had the same problem some time ago and it turned out that the bearing was broken and I had to replace it. After the replacement it was working perfectly fine for a month or so and then the machine started to make much more noise than before. I replaced the bearing again along with a gasket and now no oily substances turn up in my smoothies any more. Check it on youtube, it’s not difficult to replace it.
Małgorzata Bijak - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 19
过去 30 天: 137
总计 25,599
