跳转到主内容
ALCATEL 5015A Pixi 3 (5) 3G Teardown
英语
中文
正翻译步骤 5
步骤 5
ALCATEL 5015A Pixi 3 (5) 3G Teardown, Cables continued...: 步骤 0 中的图像 1,2 ALCATEL 5015A Pixi 3 (5) 3G Teardown, Cables continued...: 步骤 0 中的图像 2,2
Cables continued...
  • Carefully lift (with tweezers or small pliers) the connection indicated by the yellow box(s)
  • Next lift, with tweezers or spudger (carefully) the connection indicated by the blue box marker.
  • You will need a flat surface to lift carefully the clip which holds the connector indicated by the green box. You can then use a pair of tweezers (or your fingernails?) to slide the connector to the side.
在此插入翻译
在此插入翻译
在此插入翻译
您的所有投稿皆享有基于开源创作共享许可协议(CC BY-NC-SA)著作权利
