跳转到主内容
First, I would like to apologize for my poor English, I am from Brazil, but I love this site, especially because I have loved to disassemble electronic things since I was a kid. My mother always freaks out, but I always assemble everything back. Sometimes I even fix some things.
I'm writing this teardown to try to win the PSP GO or the PS3 slim, so please look with care, it was made with care. (editor’s note: WOOOOW This article is outdated. I hope you won your PSP GO or PS3 Slim.
In this teardown, I will show how to disassemble a Sony Playstation 2. I was already planning to disassemble it to clean it and fix a small issue.
Later in the repair guide, I will show how to fix a small problem I had. I sent it to a technician because the rumble effect was no longer working. He says that there was a problem in the motherboard and he needs to change it entirely, but the model is a SCPH 39001. It’s an old model. In fact, it was one of the first in the market. He says that the price to fix it was expensive and that it’s better to buy a PS2 Slim to replace mine. I remember when a bought my PS2. It cost more than R$800, almost US$400. I decided to stay with it anyway, and despite the problem, I even bought an ethernet adapter to continue playing it.
Later, talking with some friends, I found out that there is a fuse that controls the rumble effect and all that I needed to do was change it. I found out that the fuses in the mainboard are very small and fixed in the main board. It’s almost impossible to change them. The same friend gave me a tip that I can use a glass fuse and take the internal wire to use in the main board. I decided to try it and it works perfectly.
So, let’s start the teardown. Enjoy!
你所需要的
工具
查看更多...
视频概述
本篇指南是分解流程而非维修指南。 如果您要维修您的PlayStation 2,应参考我们的维修指南
  1. PlayStation 2 Teardown, PlayStation 2 Teardown: 步骤 1 中的图像 1,3 PlayStation 2 Teardown, PlayStation 2 Teardown: 步骤 1 中的图像 2,3 PlayStation 2 Teardown, PlayStation 2 Teardown: 步骤 1 中的图像 3,3
    • Here we have the system console fully assembled.
    • The USB Ports.
    • The S400 ports
    • The Optical Drive
    • The reset button
    • The eject button
  2. PlayStation 2 Teardown: 步骤 2 中的图像 1,2 PlayStation 2 Teardown: 步骤 2 中的图像 2,2
    • These are the only tools that we will need. 4 screwdrivers and a tweezer.
    • In the next photo we can see the console, the joystick, the wires and a memory card.
    I don't have. A flat head sturdriver
    myjiki - 回复
  3. PlayStation 2 Teardown: 步骤 3 中的图像 1,2 PlayStation 2 Teardown: 步骤 3 中的图像 2,2
    • In the Back, in this case we have a Ethernet adapter, to play online and to use with a Hdd.
    • And the cooler,
    • The power switch
    • The AC in.
    • The Av out
    • And the digital output (optical)
    Where can I buy an av out port replacement
    DarkruneyGaming - 回复
  4. PlayStation 2 Teardown: 步骤 4 中的图像 1,3 PlayStation 2 Teardown: 步骤 4 中的图像 2,3 PlayStation 2 Teardown: 步骤 4 中的图像 3,3
    • Lets start the teardown. At first we use a Flathead screwdriver to remove the ethernet adapter.
    • Remove these 2 screws with a Flathead screwdriver.
    • And is quite simple to pull.
    I have the ethernet adaptor with mine but no hard drive, how do you get the hard drive to work in it?
    Chris Green - 回复
    来自 Chris Green 的话:
    it is a mod. you can look it up
    DustySeven - 回复
  5. PlayStation 2 Teardown: 步骤 5 中的图像 1,1
    • This is the expansion bay, where the hard drive goes.
    I got my ps2 from flea market and it didn't have a lid to cover up the expansion bay is that ok to leave it like that
    Plushbeatzz gaming - 回复
  6. PlayStation 2 Teardown: 步骤 6 中的图像 1,2 PlayStation 2 Teardown: 步骤 6 中的图像 2,2
    • Turn the console upside down.
    • Using a small Flathead screwdriver, remove the screw protections. In this model, we have 8 of them.
  7. PlayStation 2 Teardown: 步骤 7 中的图像 1,3 PlayStation 2 Teardown: 步骤 7 中的图像 2,3 PlayStation 2 Teardown: 步骤 7 中的图像 3,3
    • Under the protection, suprise! a screw!
    • Remove all eight (8) screws with your Philips "0" screwdriver.
    • Yes, hard work!
    Hello, nice review! Can you help me out with a question i have? I have this PS2 Fat, i miss those big long screws that hold the outside shell, i need to buy them (if i can) so i can only find long screws from the PS3 4000, does those screws fit into PS2 Fat aswell? Do you know?thanks!
    Cheerious - 回复
  8. PlayStation 2 Teardown: 步骤 8 中的图像 1,2 PlayStation 2 Teardown: 步骤 8 中的图像 2,2
    • Put the console in the normal horizontal position, and pull the top cover from back to front.
    You will need to pull back the anti-tamper seal along the rear left corner.
    Wade - 回复
  9. PlayStation 2 Teardown: 步骤 9 中的图像 1,3 PlayStation 2 Teardown: 步骤 9 中的图像 2,3 PlayStation 2 Teardown: 步骤 9 中的图像 3,3
    • This model has a flat cable to the reset and eject button. Take extreme caution to not destroy it.
    • Remove the button structure just pulling with a small Flathead screwdriver.
  10. PlayStation 2 Teardown: 步骤 10 中的图像 1,1
    • The button structure comes out of the case. It have some tape to prevent a new destruction. Yes, I already destroyed this flat cable.
  11. PlayStation 2 Teardown: 步骤 11 中的图像 1,3 PlayStation 2 Teardown: 步骤 11 中的图像 2,3 PlayStation 2 Teardown: 步骤 11 中的图像 3,3
    • Remove the two screws with a Philips "0" screwdriver to deatach the controller port.
    I've tried cleaning my memory slot ports. They look fine. I'm wondering if I just have crap luck and got 2 bad cards or do I need to replace the part.
    My controller ports work fine though. Same cable I'd imagine
    AbsoluteQuinoa - 回复
  12. PlayStation 2 Teardown: 步骤 12 中的图像 1,2 PlayStation 2 Teardown: 步骤 12 中的图像 2,2
    • Here we remove the screws from the cooler and the main power switch
    After reassembly, I have a fifth screw identical to the ones shown in Step 11 and Step 12 left over, any idea where it goes?
    noob5000000 - 回复
    When you remove the power/ac plug there is a spot for the screw underneath.
    Jeff Friesen -
  13. PlayStation 2 Teardown: 步骤 13 中的图像 1,2 PlayStation 2 Teardown: 步骤 13 中的图像 2,2
    • Pull the fan up carefully so you don't break the wire.
    • Pull up the fan mount.
    I found that there was a little bit of tape holding the fan cable to the fan which prevented me from removing it until I removed the fan connector after step 18.
    Shannon Hamilton - 回复
  14. PlayStation 2 Teardown: 步骤 14 中的图像 1,2 PlayStation 2 Teardown: 步骤 14 中的图像 2,2
    • The power cable goes further inside the case. It's better to remove it in a future step.
    • The fan wire also goes more inside the case. Take extreme care not to destroy it because it is very small.
  15. PlayStation 2 Teardown: 步骤 15 中的图像 1,3 PlayStation 2 Teardown: 步骤 15 中的图像 2,3 PlayStation 2 Teardown: 步骤 15 中的图像 3,3
    • Lets turn the console upside down again, with caution because the pieces are locked, and just in the next step we can remove them.
  16. PlayStation 2 Teardown: 步骤 16 中的图像 1,2 PlayStation 2 Teardown: 步骤 16 中的图像 2,2
    • Lets remove the bottom case.
  17. PlayStation 2 Teardown: 步骤 17 中的图像 1,3 PlayStation 2 Teardown: 步骤 17 中的图像 2,3 PlayStation 2 Teardown: 步骤 17 中的图像 3,3
    • This is the power source board. remove the 4 screws where I marked in blue.
    Some older models, the PSU board is in reverse, the circuit board is flat against the inside with the caps face towards you, compared to these pictures.
    M “Moonblitz” D - 回复
  18. PlayStation 2 Teardown: 步骤 18 中的图像 1,3 PlayStation 2 Teardown: 步骤 18 中的图像 2,3 PlayStation 2 Teardown: 步骤 18 中的图像 3,3
    • Looking from the back, pull up the board, releasing from the pins of the main board.
    • Finally you can remove the power switch.
    • And this is the power source board.
    • When working on the power supply, be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply. Only handle the board by the edges.
  19. PlayStation 2 Teardown: 步骤 19 中的图像 1,3 PlayStation 2 Teardown: 步骤 19 中的图像 2,3 PlayStation 2 Teardown: 步骤 19 中的图像 3,3
    • Now we remove the expansion bay grid.
    • And now is the time to remove the fan wire from the main board, using a precision tweezer. But.. I can't, it is simply stuck. I already removed this ealier, but now is harder, so I will try later, in the end of the teardown.
    I just broke the fan pins because you have to push the connector to the side and then up. There are 2 hooks that hold the connector in place.
    Sean Brownell - 回复
  20. PlayStation 2 Teardown: 步骤 20 中的图像 1,3 PlayStation 2 Teardown: 步骤 20 中的图像 2,3 PlayStation 2 Teardown: 步骤 20 中的图像 3,3
    • Remove the isolation cover from the metal case.
    • Remove the small screws using a thin crosshead screwdriver.
    • And release the metal case from the DVD player, as indicated, using a small flat screwdriver
    There are 4 more screws that you do not have marked that I needed to remove before this metal case could be removed in the next step. Three of them on this side same as the ones circled in orange. One of the is on the other side near the audio out connector.
    Jssamp - 回复
    In the models that I took apart, there was only 3, two near the back of the DVD drive and one near the middle. The PS2 in this teardown has clearly been taken apart before and it looks like they forgot to put some screws back in and even broke the metal case where one screw should go.
    Shannon Hamilton -
  21. PlayStation 2 Teardown: 步骤 21 中的图像 1,3 PlayStation 2 Teardown: 步骤 21 中的图像 2,3 PlayStation 2 Teardown: 步骤 21 中的图像 3,3
    • Now you can remove the metal case and find the main board.
    • Look, the flat cables! Now is the time to remove them. Be gentle please.
  22. PlayStation 2 Teardown: 步骤 22 中的图像 1,3 PlayStation 2 Teardown: 步骤 22 中的图像 2,3 PlayStation 2 Teardown: 步骤 22 中的图像 3,3
    • There are 2 more and the DVD player is free.
  23. PlayStation 2 Teardown: 步骤 23 中的图像 1,2 PlayStation 2 Teardown: 步骤 23 中的图像 2,2
    • Now you can turn upside down again, and remove the metal protection.
    • This is the other side of the main board.
  24. PlayStation 2 Teardown: 步骤 24 中的图像 1,3 PlayStation 2 Teardown: 步骤 24 中的图像 2,3 PlayStation 2 Teardown: 步骤 24 中的图像 3,3
    • Well, the try to remove the cooler wire was a total failure.
    • The plug is made to deatach, but it is old. The plug had turned into one piece, and broke the soldering.
    • Well, I'll find a way to fix it. I always do =)
    I did the same thing on my slim but to my systems battery. Will this prevent the system from working?
    NJBmusic - 回复
    How did you fix same happened to me
    Francisco Torres - 回复
  25. PlayStation 2 Teardown: 步骤 25 中的图像 1,1
    • This is the end of the teardown.
    • From top, from the left: Ethernet adapter, Ps2 case, Hdd, Cooler, Cooler grid, bottom metal cover protection, screws protectors, screws, Controller board, Power swtich, Power source board, Plastic cover to isolate the power source board, top metal cover, DVD Drive, Expansion Bay cover, main board, reset/eject structure.
    You probably shouldn’t put electronics on cloth, but I guess its about 9 years too late for that.
    Johnny Danger - 回复
Pollux
于10/22/09注册
664 声望
撰写一个指南
14条评论
reverse procedures..step by step..
a to z cellutions belize - 回复
Yep in reverse, take your time or you'll be like me breaking things and having to rig it haha. Put the shielding back together, drive, power board, the other shield for hard drive. Everything, plug all connections. Even power-reset buttons. Then put it on the bottom casing, connect controller ports and close it up with top casing.
juan hernandez - 回复
How did you fix the flat cable?
Bigs - 回复
If a cable is ripped or broken, unfortunately there is no way to fix it. You will have to replace the cable.
Molten Toast -
I put a lot of layers of tape on mine, the last owner of my system was very naughty and disassembled the system when it was still under warranty, so the cable was brokem
John Doe -
do you have the list of screws required for this? i am missing a few trying to locate the size specs
Corey Smith - 回复
All i see is the 20 legged modchip-kraken lurking in one of those pics ;)
mgwara - 回复
Hi, I have a problem with a hardly used PS2. When I turn it on it only displays some coloured squares. I don’t know if the video chip has gone. Do you have any ideas??
agfa gaevart - 回复
i'd need to see it to tell you whats wrong. what do you mean by coloured squares??
Camdyn -
So I’m curious does all PS2s take thermal paste? Bcuz I noticed the cpu/gpu chip looked like it had some on it b4!
VAMPRESS23 - 回复
I've only disassembled some of the older models, and they only had thermal pads. Possibly the slim models used paste.
Shannon Hamilton -
And I was going to get inside as I need to change the coin battery but I'm not going to bother it's ridiculous just to get to it
Nakatomi Uk - 回复
This helped me teardown an old PS2 I just bought a few days ago.
With your help, I was able to give it a thorough clean inside and out and swap the BIOS battery. It looks and works almost like brand new now.
Thank you so much Pollux! 🙂❤️
SuperDadAndBreadMan - 回复
That video on this is &&^&^$^ dog $@$*. Guy does not know what he's doing and is just guessing; takes out the Optical Drive way too early.
Taylor King - 回复
添加评论
浏览统计数据:
过去 24 小时: 80
过去 7 天: 477
过去 30 天: 2,126
总计 178,834
