跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Nokia N900,请使用我们的维修手册
  1. Nokia N900 Teardown, Nokia N900 Teardown: 步骤 1 中的图像 1,1
    • First, flip the phone so the back is facing upwards.
  2. Nokia N900 Teardown: 步骤 2 中的图像 1,1
    • Next, locate the slit on the side of the phone and remove the back cover.
  3. Nokia N900 Teardown: 步骤 3 中的图像 1,1
    • Once the back has been removed, take out the battery.
  4. Nokia N900 Teardown: 步骤 4 中的图像 1,1
    • Using a small bit screwdriver, unscrew all six screws located in the back of the phone. If necessary, iFixit has 16 to 112 Bit Driver kits available for purchase.
  5. Nokia N900 Teardown: 步骤 5 中的图像 1,2 Nokia N900 Teardown: 步骤 5 中的图像 2,2
    • Once all six screws have been removed, gently pull the phone apart. You should now be left with two pieces.
  6. Nokia N900 Teardown: 步骤 6 中的图像 1,2 Nokia N900 Teardown: 步骤 6 中的图像 2,2
    • Taking the back of the phone, remove the qwerty key mat. It should come off easily.
  7. Nokia N900 Teardown: 步骤 7 中的图像 1,3 Nokia N900 Teardown: 步骤 7 中的图像 2,3 Nokia N900 Teardown: 步骤 7 中的图像 3,3
    • Using the blue opening tool, pry out the green motherboard.
  8. Nokia N900 Teardown: 步骤 8 中的图像 1,2 Nokia N900 Teardown: 步骤 8 中的图像 2,2
    • Now, take the front half of the phone. Use the screwdriver to remove all six screws.
  9. Nokia N900 Teardown: 步骤 9 中的图像 1,1
    • Once pulled apart, you should be left with two pieces.
  10. Nokia N900 Teardown: 步骤 10 中的图像 1,2 Nokia N900 Teardown: 步骤 10 中的图像 2,2
    • With the touch screen now removed from the keyboard slider, use the blue, plastic opening tool to remove the cover of the screen.
    • It is highly advised to take off one side at a time.
    • Once one section of the cover has been removed, the second cover will be removable. You have officially completed tearing down a Nokia N900.
Juan Haro
于03/13/14注册
284 声望
创作了2篇指南
团队
一条评论
Looks like the LCD flex cable ripped off on this teardown, ouch!
Leonard Putra - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 21
总计 5,493
