跳转到主内容
« 返回到所有故事
Samsung Galaxy Note 3 - Charging Assembly Replacement
Angie Willmorth -
故事图片
Samsung Galaxy Note 3 Motherboard Replacement
15分钟
Easy
我的问题
The USB port was damaged after years of use
我的修理方法
The repair was straight forward and went well.
我的建议
The link for the replacing the charging assembly is for removing the motherboard. Replacing the charging assembly does not require removal of the motherboard.
Here is what I did. Using the instructions for removing the mother board stop after step 6, "Removing the Back Chassis". Then you undo the antenna clip at the USB assembly side only, and disconnect the two cables on the USB assembly that connect it to the motherboard. Then as per your instructions in the tear down “Use spudger to remove the USB board with proper strength because the USB board is stuck with glue.”
Galaxy Note 3 (T-Mobile) Charging Assembly图片
$24.99
« 返回到所有故事
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 366
