跳转到主内容
kobo glo ereader Screen Replacement
Ismail Esen
Ismail Esen 另一个贡献者
最后更新于 October 27, 2020
30分钟
简单
社区贡献指南
你所需要的
配件
工具
当你通过这些链接购买商品时,iFixit 会赚取佣金。
  1. kobo glo ereader Screen Replacement, Remove Back Cover: 步骤 1 中的图像 1,1
    • Pry the back cover off just below the grey belt between the screen and back cover. No screws. Be careful not to lose the sliding power button while you are removing the back cover.
  2. kobo glo ereader Screen Replacement, Disconnect screen cables.: 步骤 2 中的图像 1,3 kobo glo ereader Screen Replacement, Disconnect screen cables.: 步骤 2 中的图像 2,3 kobo glo ereader Screen Replacement, Disconnect screen cables.: 步骤 2 中的图像 3,3
    • Gently pull out these 3 cables to disconnect the screen.
  3. kobo glo ereader Screen Replacement, Remove Screen and Install new one.: 步骤 3 中的图像 1,1
    • Pry the screen off the middle layer; screen is also attached by adhesive tapes. You can keep them intact for the new screen. Once screen is removed. Put on the new screen and connect the cables. Then put on the back cover. Be careful not to lose the power button.
结论
To install the new screen, connect the cables first and then install the screen onto the middle panel. Then install the back panel.
Ismail Esen
于06/08/20注册
97 声望
撰写一个指南
7条评论
I appreciate that this guide exists, but could you specify which screws to remove? What size are they? And most importantly, what's the screen number? I can't find it on Amazon at all.
Thank you for your efforts.
Soma Schicksal - 回复
Hey, it’s been some time but as I remember you do not need to remove any screws (as per the post). You just need to unplug the screen cable.
As per the screen itself, the part might have gone from Amazon or the part number changed. Maybe Ebay or AliBaba would have it?
Ismail Esen -
I have replaced the screen, it's now as easy as you explained. The double sided tape used was very hard to take out. But alas, it works now.
Soma Schicksal - 回复
Glad that it was helpful!
Ismail Esen -
is this guide for kobo glo or kobo glo hd ?
Eric Van Buggenhaut - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 27
过去 30 天: 76
总计 5,267
