跳转到主内容
iRobot Roomba S9 Plus Home Base Vacuum Bag Replacement
Charles D'Amico
Charles D'Amico4 其他贡献者
最后更新于 June 11, 2020
3 - 5 分钟
非常容易
Eventually, the bag in the iRobot Roomba S9 Plus home base will fill up and need to be replaced. When it does, this guide is here to help. Follow the instructions and your home base bag will be replaced in no time.
  1. iRobot Roomba S9 Plus Home Base Vacuum Bag Replacement, Home Base Vacuum Bag: 步骤 1 中的图像 1,1
    • Open the vacuum bag container at the top of the home base.
  2. iRobot Roomba S9 Plus Home Base Vacuum Bag Replacement: 步骤 2 中的图像 1,3 iRobot Roomba S9 Plus Home Base Vacuum Bag Replacement: 步骤 2 中的图像 2,3 iRobot Roomba S9 Plus Home Base Vacuum Bag Replacement: 步骤 2 中的图像 3,3
    • Grab the grey tab at the top of the bag and lift the bag straight out of the home base.
结论
Charles D'Amico
于01/23/20注册
226 声望
创作了2篇指南
团队
Cal Poly, Team S18-G3, White Winter 2020 Cal Poly, Team S18-G3, White Winter 2020 的会员
CPSU-WHITE-W20S18G3
4 名成员
创作了9篇指南
2指南评论
what do you do if after you change the bag , the base says there is no bag? So I replaced the old bag after I pulled stuff out , still no change. now robot won’t work . On app it says end job stuck and all it did is move off base and turn around (after hit clean) help
shelleyandboys - 回复
Can we have a tear down of the base? The bag switch sometimes doesn't want to work properly. You can resolder a new switch or just solder a jumper so it always "senses" one. There's alot of screws, sensors, wires and a big motor. It helps to know where all the screws go.
ashimo0463 - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 21
总计 1,516
