跳转到主内容
iRobot Roomba 890 IR Sensor Replacement
Caeden Foxhoven
Caeden Foxhoven4 其他贡献者
最后更新于 January 10, 2025
20分钟
中等
This guide addresses the removal of a malfunctioning or broken Roomba IR sensor. Roomba IR sensors measure how close a Roomba is to a wall or object and create a map of the cleaning area. The sensor can become defective when obscured with dust or lint. You will remove the exterior plates and casings of the Roomba to reach the motherboard where the sensor is attached. To reassemble the Roomba after the replacement, follow the steps in reverse.
你所需要的
工具
查看更多...
当你通过这些链接购买商品时,iFixit 会赚取佣金。
  1. iRobot Roomba 890 IR Sensor Replacement, IR sensor: 步骤 1 中的图像 1,1
    • Use a Phillips #2 screwdriver to remove the two 11 mm screws.
    • Remove the battery cover.
  2. iRobot Roomba 890 IR Sensor Replacement: 步骤 2 中的图像 1,2 iRobot Roomba 890 IR Sensor Replacement: 步骤 2 中的图像 2,2
    • Pull directly up on the grey pull-tabs to remove the battery.
  3. iRobot Roomba 890 IR Sensor Replacement: 步骤 3 中的图像 1,1
    • Use a Phillips #2 screwdriver to remove the one 7.7 mm screw.
    • Remove the yellow brush head.
  4. iRobot Roomba 890 IR Sensor Replacement: 步骤 4 中的图像 1,3 iRobot Roomba 890 IR Sensor Replacement: 步骤 4 中的图像 2,3 iRobot Roomba 890 IR Sensor Replacement: 步骤 4 中的图像 3,3
    • Use a Phillips #2 screwdriver to unscrew the two 11 mm screws.
    • Lift the baseplate up and off.
  5. iRobot Roomba 890 IR Sensor Replacement: 步骤 5 中的图像 1,2 iRobot Roomba 890 IR Sensor Replacement: 步骤 5 中的图像 2,2
    • Use a Phillips #1 screwdriver to remove the ten 9.3 mm screws.
    • Remove the bumper retainer ring.
  6. iRobot Roomba 890 IR Sensor Replacement: 步骤 6 中的图像 1,2 iRobot Roomba 890 IR Sensor Replacement: 步骤 6 中的图像 2,2
    • Use a Phillips #2 screwdriver to remove the two 7.5 mm screws holding the IR sensor in place.
  7. iRobot Roomba 890 IR Sensor Replacement: 步骤 7 中的图像 1,2 iRobot Roomba 890 IR Sensor Replacement: 步骤 7 中的图像 2,2
    • Use an iFixit opening tool to remove the outer plastic covering from the top of the Roomba.
  8. iRobot Roomba 890 IR Sensor Replacement: 步骤 8 中的图像 1,3 iRobot Roomba 890 IR Sensor Replacement: 步骤 8 中的图像 2,3 iRobot Roomba 890 IR Sensor Replacement: 步骤 8 中的图像 3,3
    • Use a Phillips #1 screwdriver to remove the two 9.5 mm handlebar screws; then remove the handle.
    • Use a Phillips #1 screwdriver to remove the fourteen 9.5 mm top plate screws.
    • Lift off the top plate.
  9. iRobot Roomba 890 IR Sensor Replacement: 步骤 9 中的图像 1,3 iRobot Roomba 890 IR Sensor Replacement: 步骤 9 中的图像 2,3 iRobot Roomba 890 IR Sensor Replacement: 步骤 9 中的图像 3,3
    在这个步骤中使用的工具:
    $3.99
    • Use a pair of angled tweezers to firmly grip the IR sensor plug, and pull it directly backwards to release it from the motherboard.
结论
另外一个人完成了本指南。
Caeden Foxhoven
于03/28/22注册
331 声望
创作了2篇指南
团队
UMass Dartmouth, Team 1-3, Petersen Spring 2022 UMass Dartmouth, Team 1-3, Petersen Spring 2022 的会员
UMASSD-PETERSEN-S22S1G3
3 名成员
创作了14篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 43
总计 1,080
