iRobot Roomba 870 Bumper Sensor Replacement
简介
转到步骤 1Is your Roomba not able to sense surrounding obstacles, preventing it from avoiding such barriers? If so, here is the guide to fix the problem with a simple change of the bumper sensor. All you need are the standard #0 and #1 Phillips Screwdriver heads in order to remove the two types of screws involved with this replacement.
你所需要的
Flip the iRoomba over so that the underside is facing up.
Using the Phillips #0 screwdriver, remove the 4.0 mm screw in the center of the yellow side brush.
Remove the yellow side brush.
13等其他人完成本指南。
