跳转到主内容
iRobot Roomba 860 Side Brush Replacement
Ryan Murphy
Ryan Murphy2 其他贡献者
最后更新于 June 20, 2017
55秒
简单
This guide will provide instructions to replace the side brush that directs debris and contaminants towards the debris extractor to be picked up.
你所需要的
当你通过这些链接购买商品时,iFixit 会赚取佣金。
  1. iRobot Roomba 860 Side Brush Replacement, Side Brush: 步骤 1 中的图像 1,1
    • Start by locating the yellow side brush on the underside of the iRobot Roomba 860 near the front of the device.
  2. iRobot Roomba 860 Side Brush Replacement: 步骤 2 中的图像 1,1
    • Using a Philips #2 Point Screwdriver, remove the screw located in the center of the brush.
  3. iRobot Roomba 860 Side Brush Replacement: 步骤 3 中的图像 1,2 iRobot Roomba 860 Side Brush Replacement: 步骤 3 中的图像 2,2
    • Pull up on the side brush and it should slide off, free of the motor shaft.
    • Remove any debris that could be preventing the side brush from spinning and/or replace the side brush.
结论
Ryan Murphy
于03/02/17注册
446 声望
创作了4篇指南
团队
USF Tampa, Team S13-G5, Cagle Spring 2017 USF Tampa, Team S13-G5, Cagle Spring 2017 的会员
USFT-CAGLE-S17S13G5
4 名成员
创作了4篇指南
1指南评论
What to do if the screw head is broken off? Thanks
Linda - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 22
总计 1,063
