跳转到主内容
iRobot Roomba 595 Pet Series Battery Replacement
Adrian Martinez Arbolaez
Adrian Martinez Arbolaez3 其他贡献者
最后更新于 September 9, 2024
10 - 15 分钟
中等
This guide is useful for replacing a dead battery or a battery that cannot be recharged through the dock for some reason. This guide is pretty simple can be done in 3 steps, and won't break anything important
你所需要的
工具
查看更多...
  1. iRobot Roomba 595 Pet Series Battery Replacement, Secondary Brush: 步骤 1 中的图像 1,1
    • Flip the Roomba upside down. Using the Phillips #0 screwdriver, carefully remove the 5 mm screw holding the brush in place.
  2. iRobot Roomba 595 Pet Series Battery Replacement: 步骤 2 中的图像 1,1
    • Gently pull the brush up and remove it from the device.
  3. iRobot Roomba 595 Pet Series Battery Replacement, Battery: 步骤 3 中的图像 1,1
    • Unscrew the four 10mm screws on the underside of the Roomba using a Phillips #1 screwdriver.
  4. iRobot Roomba 595 Pet Series Battery Replacement: 步骤 4 中的图像 1,1
    • Remove the bottom frame of the device.
  5. iRobot Roomba 595 Pet Series Battery Replacement: 步骤 5 中的图像 1,1
    • Grab the green tape attached to the end of the battery and remove the battery from the device.
结论
5等其他人完成本指南。
团队
USF Tampa, Team S10-G5, Thompson Fall 2017 USF Tampa, Team S10-G5, Thompson Fall 2017 的会员
USFT-THOMPSON-F17S10G5
3 名成员
创作了10篇指南
3指南评论
Pls, can i charge the roomba directly, because the base is not working??
elie moussa - 回复
Yes I think so, mine can
Big builder - 回复
Je dois chznger ma batterie qui est hs, mais les vis st morts, comment faire pour démonter le cache sans rien casser... sinon est ce que le cache et les vis peuvent être refournis par le sav?
Muriel Wendling - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 48
总计 5,577
