简介
The iPhone 8 Plus earpiece speaker also performs double duty as a loudspeaker, providing stereo sound. If your earpiece speaker is acting up, follow this guide to remove and replace it.
Power off your iPhone before beginning disassembly.
Remove the two 3.5 mm pentalobe screws from the bottom edge of the iPhone.
Use a hairdryer or prepare an iOpener and apply it to the lower edge of the iPhone for about 90 seconds in order to soften up the adhesive underneath.
Remove four Phillips (JIS) screws securing the lower display cable bracket to the logic board, of the following lengths:
Two 1.3 mm screws
One 1.4 mm screw
One 2.7 mm screw
Use the tip of a spudger or a fingernail to disconnect the large lower display connector by prying it straight up from its socket.
Remove the five Phillips screws securing the earpiece speaker bracket:
Two 1.8 mm screws
One 2.3 mm screw
One 2.4 mm screw
One 2.8 mm screw
14等其他人完成本指南。
