简介
此维修指南会教导你如何更换你
裂掉或是坏掉的 iPhone 6s Plus 屏幕。这包含了必须将前置摄像头, 光度感应器组, 屏幕EMI电磁波防护环背板贴, 以及home键组等。
若你要更换新屏幕的话, 以上这些零组件都必须动到的。
若只是要更换部分零组件, 请看考以下。
请注意:为了使Touch ID(指纹扫描)正常工作,将原始主页按钮转移到新显示屏上非常重要
您也可以参考本指南来替换以下部分:
- 听筒扬声器
- LCD shield plate
- LCD shield plate sticker
你所需要的
如要组装的话, 请按逆序操作一下步骤。
如要组装的话, 请按逆序操作一下步骤。
158等其他人完成本指南。
由衷感谢以下译者:
20%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
11条评论
with the new update, how do I avoid bricking my phone. i read an article that said if a non authorized apple person attempts to fix my phone the phone will be bricked. iphone 6 plus firmware 4.52.00 update 9.2.1.
I believe you are referring to the Error 53 bug which has since been fixed. Initially, it was caused by people attempting to update their iPhones with a Home Button other than the original factory-installed unit—the update would pause halfway through and the iPhone would be bricked.
This guide involves transferring your original Home Button to the new display, so that's not an issue in this situation, but if you were to use a new Home Button, you would still be safe since Apple's issued a fix for Error 53.
My iphone 6s plus was water damaged and I've been told that I only need to replace the screen as the parts are still in good condition. My question is in this case do I have to replace only the front panel or the full display assembly?
Did you ever get a answer ? Same problem I have
