简介
Use this guide to remove or replace a faulty logic board in your iPhone 6.
It's important to note that each iPhone's logic board and Touch ID fingerprint sensor are paired at the factory, so replacing the logic board will disable Touch ID unless you also install a replacement home button that has been properly paired to your new logic board.
You can also use this guide to replace the Upper Cable Bracket.
你所需要的
Power off your iPhone before beginning disassembly.
Remove the two 3.6 mm-long P2 Pentalobe screws next to the Lightning connector.
Pull the blue handle backwards to unlock the Anti-Clamp's arms.
Slide the arms over either the left or right edge of your iPhone.
Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
Squeeze the cups together to apply suction to the desired area.
If you don't have an Anti-Clamp, use a single suction cup to lift the front panel:
Press a suction cup onto the screen, just above the home button.
Open the iPhone by swinging the home button end of the front panel assembly away from the rear case, using the top of the phone as a hinge.
Remove the following Phillips screws from the battery connector bracket:
One 2.2 mm screw
One 3.2 mm screw
Use a plastic opening tool to gently pry the battery connector up from its socket on the logic board.
Remove the following five Phillips screws securing the front panel assembly cable bracket:
Three 1.2 mm screws
One 1.7 mm screw
One 3.1 mm screw
Remove the front panel assembly from the rear case.
Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray.
Press to eject the tray.
Use the flat end of a spudger to disconnect the Lightning connector assembly cable and fold it out of the way of the speaker.
655等其他人完成本指南。
124条评论
is there a way to swap only the memory component instead of the whole thing?
Yes, you can, but you will need to have some serious soldering skills. But in theory you can replace the memory chip with another memory chip that has been reprogrammed to fit your phone's serial number.
Didrik -
Anyone an idea, where I can find the logic board?
have you found one?
http://www.powerbookmedic.com/xcart1/hom...
I buy my Parts here
