此翻译由机器生成,尚未经过人工审核。 会说这种语言吗? 查看评论。
特色指南
iFixit的工作人员认为该指南特别酷。
你所需要的
修复工具包
本套装包含完成指南所需的所有零件和工具。
配件
工具
请按以下引导逆序重组你的设备
如果你的iPhone在更换电池后不断重启,则需要进行“硬件复位”:同时按住HOME键和电源键大概10秒直到iPhone重新启动。
如果更换电池后iPhone出现WiFi和移动数据连接问题,请尝试使用iTunes恢复iPhone。
为了体验最佳的电池性能,要对新换的电池进行校准:将电池电量放电至10%以下,然后将电池电量一次性充满至100%。
4095等其他人完成本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
256指南评论
When I removed the battery the glue was holding it in. I used the screw driver to pry it out. It sparked and I'm sure shorted the logic board. VERY IMPORTANT ONLY USE PLASTIC TOOL WHEN REMOVING BATTERY! Now I have no service. I swapped a different logic board into same phone and works fine. Any suggestions on how to fix the old logic board are appreciated.
Well, the phillips screwdriver was a bit awkward. Had to hold screwdriver top down with one hand and turn driver with other hand. All else was as stated. Never had to touch any internal parts with my bare hands just used tools. That saves the worries about static or corrosion. One part that I failed to see in write up is the small case ground. Don't loose it it will come loose once screw is out.
brriverrat - 回复 分享
A couple of suggestions.
1). If you are over about 40, some sort of hands free magnifier helps a lot - I used a headband mounted jewelers magifier called an Optivisor.
2). A pair of fine tipped tweezers and a gentle touch will let you grab the pressure contact in step 5 without getting skin oil on it.
3). Work over some sort of tray to stop small parts from rolling away.
4). If you don't have a spudger or a set of plastic case opening tools (or you know you have them, but can't recall their exact location at this moment...*cough*), the corner of an an expired credit card, or a stiff guitar pick will work to pry the battery loose. It will likely bend the card though, so do use an expired one. I used an empty Starbucks gift card I found in a junk drawer...
I'm over 40, I wish I read your tips first! both a magnifier and tweezers would have helped, and possiby prevented the spark... It's charging, fingers crossed that the tiny spark wasn't enough to fry anything!
ashleedawg - 回复 分享
