跳转到主内容
加入维修社区 - 创建账户
iPhone 3G Dock Connector Replacement
你所需要的
视频概述
  1. iPhone 3G Dock Connector Replacement, Broken Glass: 步骤 1 中的图像 1,3 iPhone 3G Dock Connector Replacement, Broken Glass: 步骤 1 中的图像 2,3 iPhone 3G Dock Connector Replacement, Broken Glass: 步骤 1 中的图像 3,3
    • Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    询问修复机器人
    添加评论
  2. iPhone 3G Dock Connector Replacement, Dock Connector: 步骤 2 中的图像 1,1
    • Remove the two Phillips #00 screws from the dock-connector end of the iPhone.
    添加评论
  3. iPhone 3G Dock Connector Replacement: 步骤 3 中的图像 1,1
    • Remove the metal handle from the suction cup. It's easier and safer to grip the suction cup's base instead of the metal handle.
    • Be very careful when opening the iPhone so that the cables under the display are not severed.
    • There is a rubber gasket between the silver front bezel and black display assembly. A bit of force is required in this step to separate the iPhone's display assembly.
    • Use a small suction cup near the Home button to gently pull up the bottom portion of the iPhone's display assembly.
    • If the display assembly is too damaged to allow the suction cup to adhere, tape with a strong adhesive such as duct tape maybe used.
    添加评论
  4. iPhone 3G Dock Connector Replacement: 步骤 4 中的图像 1,1
    • The display assembly is still connected to the iPhone by three cables, so don't try to remove it entirely just yet.
    • Rotate the display assembly up until it is at an angle of approximately 45 degrees.
    • Be careful. Sometimes cable 4 can stick to the back of the display assembly and can be pulled off and/or torn as you remove the display assembly.
    添加评论
  5. iPhone 3G Dock Connector Replacement: 步骤 5 中的图像 1,1
    • Continue to hold the display assembly with one hand, and use your other hand and a spudger to disconnect the black ribbon cable labeled "1."
    • Start from the ribbon and work your way towards the outside edge of the case.
    询问修复机器人
    添加评论
  6. iPhone 3G Dock Connector Replacement: 步骤 6 中的图像 1,1
    • Rotate the display assembly up until it is roughly vertical. This will allow easier access for disconnecting the remaining cables.
    • Use a spudger to disconnect the black ribbon cable labeled "2."
    询问修复机器人
    添加评论
  7. iPhone 3G Dock Connector Replacement: 步骤 7 中的图像 1,1
    • Use a spudger to flip up the white plastic tab holding the remaining ribbon cable in place. The white tab will rotate up 90 degrees, releasing the ribbon cable.
    • Slide the black ribbon cable out of its connector, and remove the display assembly from the iPhone.
    添加评论
  8. iPhone 3G Dock Connector Replacement: 步骤 8 中的图像 1,1
    • Insert your SIM eject tool or a paper clip into the hole next to the headphone jack.
    • Press down on the tool until the SIM card tray pops out.
    • Grasp the SIM card tray and slide it out of the iPhone.
    询问修复机器人
    添加评论
  9. iPhone 3G Dock Connector Replacement: 步骤 9 中的图像 1,1
    • Use a spudger to disconnect the ribbon cable labeled "4."
    询问修复机器人
    添加评论
  10. iPhone 3G Dock Connector Replacement: 步骤 10 中的图像 1,1
    • Use a spudger to disconnect the ribbon cable labeled "5."
    询问修复机器人
    添加评论
  11. iPhone 3G Dock Connector Replacement: 步骤 11 中的图像 1,2 iPhone 3G Dock Connector Replacement: 步骤 11 中的图像 2,2
    • Use a spudger to disconnect the ribbon cable labeled "6."
    • If you have an iPhone 3GS, refer to picture 2 and use a spudger to disconnect the ribbon cable labeled "7."
    询问修复机器人
    添加评论
  12. iPhone 3G Dock Connector Replacement: 步骤 12 中的图像 1,1
    • Carefully peel up the small sticker labeled "Do not remove."
    添加评论
  13. iPhone 3G Dock Connector Replacement: 步骤 13 中的图像 1,1
    • Remove the following 8 screws:
    • Five 2.3 mm Phillips #00 screws with partial threads securing the logic board to the rear panel.
    • Two 2.3 mm Phillips #00 screws with full threads securing the logic board and camera.
    • One 2.9 mm Phillips #00 screw from beneath the "Do not remove" sticker.
    询问修复机器人
    添加评论
  14. iPhone 3G Dock Connector Replacement: 步骤 14 中的图像 1,1
    • Use a spudger to gently remove the camera retaining clip, (formerly secured by the removed screw) and gently pry the camera up and out of its housing in the rear panel. The camera cannot be removed entirely yet because it's connected to the bottom of the logic board.
    询问修复机器人
    添加评论
  15. iPhone 3G Dock Connector Replacement: 步骤 15 中的图像 1,1
    • Use a spudger to gently pry up the end of the logic board closest to the dock connector.
    • There is a small golden grounding tab on the logic board adjacent to the 'Do not remove' sticker. Be very careful this does not snag on the side of the case when prying up the logic board; it breaks easily! If you have signal problems after removing the logic board, check this ground tab.
    • If the board won't lift up, double check to make sure all 8 screws securing the logic board have been removed.
    询问修复机器人
    添加评论
  16. iPhone 3G Dock Connector Replacement: 步骤 16 中的图像 1,1
    • Slide the logic board towards the dock connector and out of the iPhone.
    询问修复机器人
    添加评论
  17. iPhone 3G Dock Connector Replacement: 步骤 17 中的图像 1,1
    • Remove the following 3 screws:
    • Two 1.5 mm Phillips #00 screws, one on either side of the dock connector.
    • One 2.4 mm Phillips #00 screw near the ribbon cable labeled "4."
    添加评论
  18. iPhone 3G Dock Connector Replacement: 步骤 18 中的图像 1,1
    • Lift the dock connector assembly up and out of the iPhone.
    • When inserting the new assembly, ensure the screw holes of the assembly rest ABOVE the bezel's holes.
    添加评论
结论
取消:我没有完成这个指南。
172等其他人完成本指南。
iRobot
于09/24/09注册
1 声望
创作了636篇指南
1指南评论
Hm, swapped the docking assembly, but now my phone will only show the apple logo for a few seconds, then goes black. Switched back to my original dock connector, but I have the same problem. Tried the power+home trick, but no dice. Don't think the battery is short cirquited, but not sure, tried to measure it, only got about 3.6 volt, but unsure where which og the pins to measure on.
I was able to boot the phone before swapping out the dock (wanted to swap it because I had no sound from the speaker plus no wifi antenna due to a ripped cord) but not after swapping back. I've gone over all connections and I am fairly sure everyting is hooked up as it should.
Stuck.
mortenskogly - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 90
总计 303,527
