你所需要的
在这个步骤中使用的工具:iOpener$14.99
Use a hair dryer or heat gun to heat the bottom edge of the screen until it's hot to the touch.
Apply a suction handle to the bottom edge of the screen.
While holding the frame down with one hand, pull up on the handle with a strong, steady force to create a gap between the screen and the frame.
Insert the tip of an opening pick into the gap.
Two delicate cables connecting the screen to the phone—one next to the Action button and the other about halfway between the volume down button and the bottom of the phone.
Multiple spring contacts around the perimeter of the phone.
Continue sliding your pick around the top right corner and across the top edge to separate the adhesive and release the two metal clips.
Slide the opening pick down the left edge of the screen to separate the remaining adhesive and release the last two metal clips.
Swing open the screen over the left edge of the phone and support it with a clean, sturdy object.
Use a tri-point Y000 screwdriver to remove the two 0.9 mm‑long screws securing the front sensor connector and screen connector covers.
Use tweezers or your fingers to lift the front sensor cover to a 90-degree angle and unhook it from its slot in the logic board.
Lift the cover out of its slot and remove it.
Use the tip of a spudger to pry up and disconnect the screen press connector.
Repeat for the front sensor press connector.
