跳转到主内容
加入维修社区 - 创建账户
iPhone 16 Pro Max Front Camera Installation
仅作为前提条件
本指南仅提供前提条件!本指南是另一个程序的一部分,不能单独使用。
你所需要的
  1. iPhone 16 Pro Max Front Camera Installation, Install the front camera assembly: 步骤 1 中的图像 1,2 iPhone 16 Pro Max Front Camera Installation, Install the front camera assembly: 步骤 1 中的图像 2,2
    • Lay the front camera assembly in its recess.
    • Gently tuck the camera flex cables into the gap between the rear camera assembly and the earpiece speaker assembly.
  2. iPhone 16 Pro Max Front Camera Installation: 步骤 2 中的图像 1,2 iPhone 16 Pro Max Front Camera Installation: 步骤 2 中的图像 2,2
    • Use your finger or a spudger to press and connect the two camera connectors onto the logic board.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down in the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  3. iPhone 16 Pro Max Front Camera Installation: 步骤 3 中的图像 1,1
    • Use your finger or a spudger to press and connect the earpiece speaker and the mmWave antenna connectors onto the logic board.
终点
Arthur Shi
于01/03/18注册
324,650 声望
创作了802篇指南
团队
iFixit iFixit 的会员
Staff
124 名成员
创作了24,259篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 54
