跳转到主内容
加入维修社区 - 创建账户
iPhone 16 Front Camera Assembly Removal
仅作为前提条件
本指南仅提供前提条件!本指南是另一个程序的一部分,不能单独使用。
你所需要的
  1. iPhone 16 Front Camera Assembly Removal, Before you begin: 步骤 1 中的图像 1,2 iPhone 16 Front Camera Assembly Removal, Before you begin: 步骤 1 中的图像 2,2
    • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard.
    • Unplug any cables from your phone.
    • Hold the power and either volume buttons and slide to power off your phone.
  2. iPhone 16 Front Camera Assembly Removal, Tape over any cracks: 步骤 2 中的图像 1,2 iPhone 16 Front Camera Assembly Removal, Tape over any cracks: 步骤 2 中的图像 2,2
    • If your screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
    • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
  3. iPhone 16 Front Camera Assembly Removal, Remove the pentalobe screws: 步骤 3 中的图像 1,2 iPhone 16 Front Camera Assembly Removal, Remove the pentalobe screws: 步骤 3 中的图像 2,2
    • Use a P2 pentalobe driver to remove the two 7.7 mm-long screws on either side of the charging port.
  4. iPhone 16 Front Camera Assembly Removal, Mark your opening picks: 步骤 4 中的图像 1,3 iPhone 16 Front Camera Assembly Removal, Mark your opening picks: 步骤 4 中的图像 2,3 iPhone 16 Front Camera Assembly Removal, Mark your opening picks: 步骤 4 中的图像 3,3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    • Apple sells an Adhesive Cutter tool for cutting the display adhesive safely in their Self Repair Store.
  5. iPhone 16 Front Camera Assembly Removal, Heat the bottom edge: 步骤 5 中的图像 1,1
    在这个步骤中使用的工具:
    iOpener
    $14.99
    • Use a hair dryer or heat gun to heat the bottom edge of the back glass until it's hot to the touch.
    • You can also use an iOpener to heat the back glass. Follow these instructions to heat and apply the iOpener properly.
  6. iPhone 16 Front Camera Assembly Removal, Insert an opening pick: 步骤 6 中的图像 1,3 iPhone 16 Front Camera Assembly Removal, Insert an opening pick: 步骤 6 中的图像 2,3 iPhone 16 Front Camera Assembly Removal, Insert an opening pick: 步骤 6 中的图像 3,3
    • Apply a suction handle to the bottom edge of the back glass.
    • While supporting the frame with one hand, pull up on the handle with a strong, steady force to create a gap between the back glass and the frame.
    • Insert the tip of an opening pick into the gap.
  7. iPhone 16 Front Camera Assembly Removal, Back glass information: 步骤 7 中的图像 1,1
    • As you slice the adhesive securing the back glass in the following steps, don't insert your pick deeper than 3 mm to avoid damaging the following areas:
    • A delicate cable connecting the back glass to the phone, right next to the volume down button. Don't insert your pick here to avoid slicing the cable.
    • Multiple spring contacts around the perimeter of the phone.
  8. iPhone 16 Front Camera Assembly Removal, Heat the right edge: 步骤 8 中的图像 1,1
    • Use a hair dryer or heat gun to heat the right edge of the back glass until it's hot to the touch.
  9. iPhone 16 Front Camera Assembly Removal, Separate the bottom right adhesive: 步骤 9 中的图像 1,3 iPhone 16 Front Camera Assembly Removal, Separate the bottom right adhesive: 步骤 9 中的图像 2,3 iPhone 16 Front Camera Assembly Removal, Separate the bottom right adhesive: 步骤 9 中的图像 3,3
    • Don't insert your pick deeper than 3 mm to avoid damaging the spring contacts.
    • Slide your pick around the bottom right corner and to the volume down button to separate the adhesive and release the metal clip.
    • Don't slide past the volume buttons to avoid damaging the wireless charging cable.
    • You'll hear and feel the metal clip release as you pass it.
    • Leave this pick inserted to prevent the adhesive from resealing.
  10. iPhone 16 Front Camera Assembly Removal, Heat the left edge: 步骤 10 中的图像 1,1
    • Use a hair dryer or heat gun to heat the left edge of the back glass until it's hot to the touch.
  11. iPhone 16 Front Camera Assembly Removal, Separate the left adhesive: 步骤 11 中的图像 1,3 iPhone 16 Front Camera Assembly Removal, Separate the left adhesive: 步骤 11 中的图像 2,3 iPhone 16 Front Camera Assembly Removal, Separate the left adhesive: 步骤 11 中的图像 3,3
    • Insert a second opening pick at the bottom edge.
    • Slide the second pick around the bottom left corner and along the left edge of the screen to separate the adhesive and release the metal clips.
    • You'll hear and feel the metal clips release as you pass them.
    • Leave this pick inserted at the top left corner to prevent the adhesive from resealing.
  12. iPhone 16 Front Camera Assembly Removal, Heat the top edge: 步骤 12 中的图像 1,1
    • Use a hair dryer or heat gun to heat the top edge of the back glass until it's hot to the touch.
  13. iPhone 16 Front Camera Assembly Removal, Separate the top right adhesive: 步骤 13 中的图像 1,3 iPhone 16 Front Camera Assembly Removal, Separate the top right adhesive: 步骤 13 中的图像 2,3 iPhone 16 Front Camera Assembly Removal, Separate the top right adhesive: 步骤 13 中的图像 3,3
    • Slide your second opening pick around the top left corner and along the top edge to separate the adhesive and release the metal clips.
    • Continue sliding your pick around the top right corner until you reach the Action button.
  14. iPhone 16 Front Camera Assembly Removal, Reposition the back glass: 步骤 14 中的图像 1,3 iPhone 16 Front Camera Assembly Removal, Reposition the back glass: 步骤 14 中的图像 2,3 iPhone 16 Front Camera Assembly Removal, Reposition the back glass: 步骤 14 中的图像 3,3
    • At this point, the back glass should be free from the frame. If the back glass feels stuck, go back around the perimeter with your pick to check for missed sections of adhesive or stuck clips.
    • Swing open the back glass to the right of the phone to separate the remaining adhesive.
    • Support the back glass with a clean, sturdy object.
    • Remove the opening picks before continuing.
  15. iPhone 16 Front Camera Assembly Removal, Remove the middle connector cover screws: 步骤 15 中的图像 1,2 iPhone 16 Front Camera Assembly Removal, Remove the middle connector cover screws: 步骤 15 中的图像 2,2
    • Use a tri-point Y000 driver to remove the two 1 mm‑long screws securing the middle connector cover.
  16. iPhone 16 Front Camera Assembly Removal, Remove the middle connector cover: 步骤 16 中的图像 1,3 iPhone 16 Front Camera Assembly Removal, Remove the middle connector cover: 步骤 16 中的图像 2,3 iPhone 16 Front Camera Assembly Removal, Remove the middle connector cover: 步骤 16 中的图像 3,3
    • Insert the point of a spudger in either cutout on the middle connector cover.
    • Slide the cover towards the left edge of the phone and release its hook from its slot on the logic board.
    • Remove the cover.
  17. iPhone 16 Front Camera Assembly Removal, Disconnect the battery: 步骤 17 中的图像 1,2 iPhone 16 Front Camera Assembly Removal, Disconnect the battery: 步骤 17 中的图像 2,2
    • Use the point of a spudger to pry up and disconnect the battery press connector.
  18. iPhone 16 Front Camera Assembly Removal, Disconnect the wireless charging coil: 步骤 18 中的图像 1,2 iPhone 16 Front Camera Assembly Removal, Disconnect the wireless charging coil: 步骤 18 中的图像 2,2
    • Use the point of a spudger to pry up and disconnect the wireless charging coil press connector.
  19. iPhone 16 Front Camera Assembly Removal, Remove the back glass: 步骤 19 中的图像 1,1
    • Lift the back glass off the frame and remove it.
  20. iPhone 16 Front Camera Assembly Removal, Remove the top bracket screws: 步骤 20 中的图像 1,2 iPhone 16 Front Camera Assembly Removal, Remove the top bracket screws: 步骤 20 中的图像 2,2
    • Use a screwdriver to remove the four screws securing the top bracket:
    • One 3.5 mm-long Phillips screw
    • Two 1.4 mm-long Phillips screw
    • One 1.0 mm-long tri-point Y000 screw
  21. iPhone 16 Front Camera Assembly Removal, Remove the top bracket: 步骤 21 中的图像 1,2 iPhone 16 Front Camera Assembly Removal, Remove the top bracket: 步骤 21 中的图像 2,2
    • Use tweezers, or your fingers, to remove the top bracket.
  22. iPhone 16 Front Camera Assembly Removal, Disconnect the front camera: 步骤 22 中的图像 1,3 iPhone 16 Front Camera Assembly Removal, Disconnect the front camera: 步骤 22 中的图像 2,3 iPhone 16 Front Camera Assembly Removal, Disconnect the front camera: 步骤 22 中的图像 3,3
    • Use the point of a spudger to pry up and disconnect the two front camera press connectors.
    • The second press connector is underneath the first.
  23. iPhone 16 Front Camera Assembly Removal, Remove the front camera: 步骤 23 中的图像 1,3 iPhone 16 Front Camera Assembly Removal, Remove the front camera: 步骤 23 中的图像 2,3 iPhone 16 Front Camera Assembly Removal, Remove the front camera: 步骤 23 中的图像 3,3
    • Insert the point of a spudger between the top edge of the front camera and the frame.
    • Lift the front camera out of the frame and remove it.
终点
Alex Diaz-Kokaisl
于01/16/22注册
219,588 声望
创作了1,064篇指南
团队
iFixit iFixit 的会员
Staff
124 名成员
创作了24,126篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 35
总计 287
