跳转到主内容
iPhone 15 Plus Screen Replacement
你所需要的
  1. iPhone 15 Plus Screen Replacement, Prepare your phone for disassembly: 步骤 1 中的图像 1,2 iPhone 15 Plus Screen Replacement, Prepare your phone for disassembly: 步骤 1 中的图像 2,2
    • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard.
    • Unplug any cables from your phone.
    • Hold the power and either volume buttons and slide to power off your phone.
  2. iPhone 15 Plus Screen Replacement, Tape over any cracks: 步骤 2 中的图像 1,2 iPhone 15 Plus Screen Replacement, Tape over any cracks: 步骤 2 中的图像 2,2
    • If your screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
    • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
  3. iPhone 15 Plus Screen Replacement, Mark your opening picks: 步骤 3 中的图像 1,3 iPhone 15 Plus Screen Replacement, Mark your opening picks: 步骤 3 中的图像 2,3 iPhone 15 Plus Screen Replacement, Mark your opening picks: 步骤 3 中的图像 3,3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    • Apple sells an Adhesive Cutter tool for cutting the display adhesive safely in their Self Repair Store.
  4. iPhone 15 Plus Screen Replacement, Remove the pentalobe screws: 步骤 4 中的图像 1,1
    • Use a P2 pentalobe driver to remove the two 7.7 mm-long screws on either side of the charging port.
  5. iPhone 15 Plus Screen Replacement, Heat the bottom edge: 步骤 5 中的图像 1,1
    • Use a hair dryer or heat gun to heat the bottom edge of the screen until it's hot to the touch.
    • Be careful not to heat the phone hotter than this—the battery is susceptible to heat damage.
  6. iPhone 15 Plus Screen Replacement, Insert an opening pick: 步骤 6 中的图像 1,3 iPhone 15 Plus Screen Replacement, Insert an opening pick: 步骤 6 中的图像 2,3 iPhone 15 Plus Screen Replacement, Insert an opening pick: 步骤 6 中的图像 3,3
    • Apply a suction handle to the bottom edge of the screen.
    • Pull up on the handle with a strong, steady force to create a gap between the screen and the frame.
    • Insert the tip of an opening pick into the gap.
  7. iPhone 15 Plus Screen Replacement, Screen information: 步骤 7 中的图像 1,2 iPhone 15 Plus Screen Replacement, Screen information: 步骤 7 中的图像 2,2
    • As you slice the adhesive securing the screen in the next steps, be careful of the following areas:
    • There are two delicate cables connecting the screen to the phone, one just above the mute switch, and the other about halfway between the volume down button and the bottom of the phone.
    • There are multiple spring contacts around the perimeter of the phone. Be extra careful not to insert your pick deeper than suggested in these locations to avoid bending the contacts.
  8. iPhone 15 Plus Screen Replacement, Separate the bottom edge adhesive: 步骤 8 中的图像 1,3 iPhone 15 Plus Screen Replacement, Separate the bottom edge adhesive: 步骤 8 中的图像 2,3 iPhone 15 Plus Screen Replacement, Separate the bottom edge adhesive: 步骤 8 中的图像 3,3
    • Don't insert your opening pick deeper than 3 mm along the bottom edge.
    • Slide your pick back and forth along the bottom edge to separate the adhesive.
    • Leave your pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
  9. iPhone 15 Plus Screen Replacement, Heat the right edge: 步骤 9 中的图像 1,1
    • Heat the right edge of the screen until it's hot to the touch.
  10. iPhone 15 Plus Screen Replacement, Separate the right edge adhesive: 步骤 10 中的图像 1,3 iPhone 15 Plus Screen Replacement, Separate the right edge adhesive: 步骤 10 中的图像 2,3 iPhone 15 Plus Screen Replacement, Separate the right edge adhesive: 步骤 10 中的图像 3,3
    • Don't insert your pick deeper than 5 mm along the right edge.
    • Insert a second opening pick to the right of the first one.
    • Slide the pick along the right edge of the screen to release the clips and separate the adhesive securing it.
  11. iPhone 15 Plus Screen Replacement, Heat the top edge: 步骤 11 中的图像 1,1
    • Heat the top edge of the screen until it's hot to the touch.
  12. iPhone 15 Plus Screen Replacement, Separate the top edge adhesive: 步骤 12 中的图像 1,2 iPhone 15 Plus Screen Replacement, Separate the top edge adhesive: 步骤 12 中的图像 2,2
    • Don't insert your pick deeper than 3 mm along the top edge.
    • Insert a third opening pick in the top right corner and slide it along the top edge to release the two clips and adhesive securing it.
  13. iPhone 15 Plus Screen Replacement, Heat the left edge: 步骤 13 中的图像 1,1
    • Heat the left edge of the screen until it's hot to the touch.
  14. iPhone 15 Plus Screen Replacement, Separate the left edge adhesive: 步骤 14 中的图像 1,3 iPhone 15 Plus Screen Replacement, Separate the left edge adhesive: 步骤 14 中的图像 2,3 iPhone 15 Plus Screen Replacement, Separate the left edge adhesive: 步骤 14 中的图像 3,3
    • Don't insert your pick deeper than 3 mm along the left edge to avoid the two cables connecting the screen to the phone.
    • Slide your pick around the top left corner of the screen and along the left edge to release the clips and separate the adhesive securing it.
  15. iPhone 15 Plus Screen Replacement, Swing open the screen: 步骤 15 中的图像 1,2 iPhone 15 Plus Screen Replacement, Swing open the screen: 步骤 15 中的图像 2,2
    • Gently swing open the screen over the left edge of the phone.
    • If the screen feels stuck, go back around the perimeter to check for missed sections of adhesive or stuck clips.
    • Rest the screen against a box or similar object so it doesn't strain the cables.
  16. iPhone 15 Plus Screen Replacement, Unfasten the front sensor connector cover: 步骤 16 中的图像 1,1
    • Use a tri-point Y000 driver to remove the 0.9 mm‑long screw securing the front sensor connector cover.
  17. iPhone 15 Plus Screen Replacement, Remove the cover: 步骤 17 中的图像 1,3 iPhone 15 Plus Screen Replacement, Remove the cover: 步骤 17 中的图像 2,3 iPhone 15 Plus Screen Replacement, Remove the cover: 步骤 17 中的图像 3,3
    在这个步骤中使用的工具:
    • Use tweezers to lift the cover to a 90-degree angle.
    • Unhook the cover from its slot in the logic board.
    • Remove the cover.
    • During reassembly, insert the cover at a 90-degree angle to re-engage the hook before laying it flat against the press connector.
  18. iPhone 15 Plus Screen Replacement, Disconnect the front sensor: 步骤 18 中的图像 1,2 iPhone 15 Plus Screen Replacement, Disconnect the front sensor: 步骤 18 中的图像 2,2
    • Use the tip of an opening pick to pry up and disconnect the front sensor press connector.
    • To reconnect a press connector, align it over its socket and gently press down on one side until it clicks into place, then press down on the other side.
  19. iPhone 15 Plus Screen Replacement, Unfasten the screen connector cover: 步骤 19 中的图像 1,1
    • Use your tri-point Y000 driver to remove the 0.9 mm‑long screw securing the screen connector cover.
  20. iPhone 15 Plus Screen Replacement, Remove the cover: 步骤 20 中的图像 1,3 iPhone 15 Plus Screen Replacement, Remove the cover: 步骤 20 中的图像 2,3 iPhone 15 Plus Screen Replacement, Remove the cover: 步骤 20 中的图像 3,3
    • Use tweezers to lift the cover and unlatch it from its hook on the logic board.
    • Remove the cover.
  21. iPhone 15 Plus Screen Replacement, Disconnect the screen: 步骤 21 中的图像 1,2 iPhone 15 Plus Screen Replacement, Disconnect the screen: 步骤 21 中的图像 2,2
    • Use the tip of an opening pick to pry up and disconnect the screen press connector.
  22. iPhone 15 Plus Screen Replacement, Remove the screen: 步骤 22 中的图像 1,3 iPhone 15 Plus Screen Replacement, Remove the screen: 步骤 22 中的图像 2,3 iPhone 15 Plus Screen Replacement, Remove the screen: 步骤 22 中的图像 3,3
    • Remove the screen.
    • During reassembly, use this guide to reapply adhesive and install your new screen.
    • Be careful not to damage any of the spring contacts as you clean the frame.
结论
To reassemble your phone, follow this guide to reapply adhesive and install your screen.
After your repair, depending on the replacement part, you may be able to calibrate it using Apple's Repair Assistant, available as of iOS 18. Update your device, navigate to Settings General About Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
5等其他人完成本指南。
Clay Eickemeyer
于09/19/22注册
96,368 声望
创作了466篇指南
团队
Guide Team Guide Team 的会员
Staff
10 名成员
创作了15,943篇指南
4指南评论
No link for screen?
Josh Clayman - 回复
Battery still plugged in? You would need to take the back glass also
Smarterthanyou - 回复
You actually won’t need to unplug the battery before hand. Just attach the new screen, and if the phone is still “on” do a soft reset, and the screen will start normally
Rob Preston -
Incomplete guide. No instructions for reassembly. Part ordered directly from ifixit is different than part removed. Unsure how to proceed. Refund requested
Blake Rhodenizer - 回复
添加评论
浏览统计数据:
过去 24 小时: 36
过去 7 天: 226
过去 30 天: 1,241
总计 16,103
