简介
iPhone电池可容纳80%的电量,最多可进行500个充电周期,对于大多数用户而言,这大约可持续18-24个月。之后,你的iPhone可能需要更频繁地充电,而iOS可能会警告你性能受到影响(换句话说,你的手机运行速度会变慢)。使用本指南更换电池,并将iPhone恢复到新的性能。
如果电池膨胀,请如何处理膨胀的电池;请采取适当的预防措施。
'“注意”':维修后,即使使用原装的Apple零件,你的iPhone也会显示有关电池“正品”的警告。如果你的iPhone正常运行,则可以放心地忽略该警告。
为了获得最佳性能,请在完成本指南后,校准新安装的电池:将其充电至100%,并继续充电至少两个小时。然后使用你的iPhone,直到由于电池电量不足而将其关闭。最后,不间断充电至100%。
你所需要的
开始拆卸前,请关闭iPhone的电源。
卸下iPhone底部边缘的两颗6.7毫米长的五角螺丝。
Please explain how to power off the phone when the broken screen is not responding to touch.
从尖端测量 3 毫米,并用永久性记号笔标记三角撬片。
Got to step 2 and realized the fix kit doesn't include an opening pick! Looks like a guitar pick, and I have those lying around. Is that expected? Looks like the pick is used in many steps below. There's a little blue crowbar that isn't mentioned in the instructions. Perhaps that replaces the opening pick?
Hi! I can't see which guide you were using when writing this comment. Can you reply here with which guide and fix kit you used?
I see you posted this in Meta. I hope it's resolved soon! In the meantime, a guitar pick may work well enough for your repair.
what fix kit?
My fix kit didn't include an opening pick either
My AliExpress refurbished screen came with a pick that has a coin-like circle that pops out, so no modification was necessary
将蓝色手柄拉向铰链以解除开启模式。
将手臂滑过 iPhone 的左边缘或右边缘。
将吸盘放在屏幕上主页按钮的正上方——一个在前面,一个在后面。
向下推吸盘以将吸力施加到所需区域。
用力、恒定的压力向上拉吸盘,在屏幕和后壳之间形成微小的间隙。
将撬片插入屏幕塑料边框下方的缝隙中。
If you have the small single suction cup. You have to get glass up enough to get under glass and touch sensor. I inserted pick too soon and separated glass from screen. $200 mistake. ;) Worth buying suction vise tool to get screen high enough. I would try it again after this mistake. with that vise tool.
在 iPhone 的右下角插入撬片以分离粘合剂。
沿着右侧边缘滑动撬片到右上角。
在进行下一步之前将撬片留在右上角。
使用 Y000 螺丝刀卸下固定SIM卡读卡器连接器盖的两颗1.4毫米长的螺丝。
将新的替换零件与原始零件进行比较——在安装之前,你可能需要转移剩余的组件或从新零件上取下粘性衬板。
要重新组装设备,请按逆序执行上述步骤。
将你的电子垃圾带到R2或e-Stewards认证回收商。
维修没有按计划进行吗?尝试一些基本排障, 或者向我们的iPhone 12 Pro 社区 寻求帮助。
要重新组装设备,请按逆序执行上述步骤。
31等其他人完成本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
10条评论
Thanks this is incredibly detailed.
Hello! Do you really need to take away the Taptic Engine and so many parts just to replace the battery?
nope, steps 31-40 are not necessary
AEV -
Everything went fine with the iFixit battery but now I have to deal with an "Important Battery Message" which I can't delete, and the badge number over the settings icon.
That is why we need to force apple to remove serial pairing
That is why we need to force apple to remove serial pairing to logic board
Step 3 references "waterproof seals" around the display which need to be replaced. But there is no description of this procedure, or depiction of what the seals look like. Nor are there any "waterproof seals" available for purchase.
The battery replacement kit includes an adhesive ring for the screen--is this the same thing? Even so there is no procedure shown for how to replace it. I imagine this requires very careful alignment so it would be helpful to have some guidance to make sure it is done correctly.
Please update the instructions to include how to replace the waterproof seals, to make it clear that it is, or is not, the same thing as the screen adhesive, and how to install the adhesive.
Having completed the repair, everything seems to work great other than my phone's battery is constantly showing 1% as the battery level. Has anyone else had this problem?
Caution regarding the waterproof seals, as they could potentially harm the plastic inserts surrounding the display, leaving the screen vulnerable without its protective plastic casing. To mitigate this risk, it's advisable to apply heat to the left portion of the iPhone where the flex cables are located to soften the seals.
What is below the Taptic Engine with the two prongs?
Kgraves - 回复
