跳转到主内容
iPad Mini CDMA Front Facing Camera Cable Replacement
Walter Galan
Walter Galan3 其他贡献者
最后更新于 May 7, 2024
没有估计
困难
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独使用。
Use this guide to replace the front-facing camera.
你所需要的
工具
查看更多...
  1. iPad Mini CDMA Front Facing Camera Cable Replacement, Front Facing Camera Cable: 步骤 1 中的图像 1,2 iPad Mini CDMA Front Facing Camera Cable Replacement, Front Facing Camera Cable: 步骤 1 中的图像 2,2
    在这个步骤中使用的工具:
    • Use a pair of tweezers to peel up and remove the small piece of tape covering the front-facing camera cable connector.
  2. iPad Mini CDMA Front Facing Camera Cable Replacement: 步骤 2 中的图像 1,1
    • The front-facing camera cable connector is secured with pieces of tape that wrap up around the sides of the cable and are fastened to two small metal plates.
    • In the next two steps, you will be prying the two metal plates up and out from the center of the cable.
  3. iPad Mini CDMA Front Facing Camera Cable Replacement: 步骤 3 中的图像 1,3 iPad Mini CDMA Front Facing Camera Cable Replacement: 步骤 3 中的图像 2,3 iPad Mini CDMA Front Facing Camera Cable Replacement: 步骤 3 中的图像 3,3
    • Use a plastic opening tool to gently pry the lower metal plate up from the front-facing camera cable connector.
    • Being careful not to break the plate or the tape attached to it, pry it up and fold it away from the front-facing camera cable connector.
  4. iPad Mini CDMA Front Facing Camera Cable Replacement: 步骤 4 中的图像 1,3 iPad Mini CDMA Front Facing Camera Cable Replacement: 步骤 4 中的图像 2,3 iPad Mini CDMA Front Facing Camera Cable Replacement: 步骤 4 中的图像 3,3
    • Gently pry the second metal plate up from the front-facing camera cable connector.
    • Again, carefully pry the plate up and away from the front-facing camera cable connector.
  5. iPad Mini CDMA Front Facing Camera Cable Replacement: 步骤 5 中的图像 1,2 iPad Mini CDMA Front Facing Camera Cable Replacement: 步骤 5 中的图像 2,2
    • Use a plastic opening tool to pry the front-facing camera cable's connector up from its socket on the logic board.
  6. iPad Mini CDMA Front Facing Camera Cable Replacement: 步骤 6 中的图像 1,3 iPad Mini CDMA Front Facing Camera Cable Replacement: 步骤 6 中的图像 2,3 iPad Mini CDMA Front Facing Camera Cable Replacement: 步骤 6 中的图像 3,3
    • Use a pair of tweezers to peel up the top of the rectangular piece of tape covering the bend in the front-facing camera cable.
    • Do not try to remove the tape, as it is connected below the cable.
    • Bend the tape up out of the way of the front-facing camera cable.
  7. iPad Mini CDMA Front Facing Camera Cable Replacement: 步骤 7 中的图像 1,2 iPad Mini CDMA Front Facing Camera Cable Replacement: 步骤 7 中的图像 2,2
    • Gently fold the front-facing camera cable upwards (roughly at a 90-degree angle), exposing the bottom side of it.
  8. iPad Mini CDMA Front Facing Camera Cable Replacement: 步骤 8 中的图像 1,3 iPad Mini CDMA Front Facing Camera Cable Replacement: 步骤 8 中的图像 2,3 iPad Mini CDMA Front Facing Camera Cable Replacement: 步骤 8 中的图像 3,3
    • While holding the front-facing camera cable up, use the tip of a spudger to separate the piece of tape adhered to the bottom side of the corner of the cable.
    • The tape is folded in half to attach to both the underside of the front-facing camera cable and the top side of the cable directly beneath it (headphone jack cable).
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 6
总计 613
