跳转到主内容
加入维修社区 - 创建账户
iPad Mini 6 Screen Replacement
你所需要的
    1. iPad Mini 6 Screen Replacement, Apply tape to a cracked screen: 步骤 1 中的图像 1,3 iPad Mini 6 Screen Replacement, Apply tape to a cracked screen: 步骤 1 中的图像 2,3 iPad Mini 6 Screen Replacement, Apply tape to a cracked screen: 步骤 1 中的图像 3,3
      • Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
      • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
      • Wear safety glasses to protect your eyes, and be careful not to damage the LCD screen.
      询问修复机器人
      添加评论
    1. iPad Mini 6 Screen Replacement, Heat the bottom edge: 步骤 2 中的图像 1,1
      • Completely power off your device before you begin.
      • Apply a heated iOpener to the bottom edge of the device for 90 seconds to loosen the adhesive underneath.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device.
      询问修复机器人
      添加评论
    2. iPad Mini 6 Screen Replacement, Screen removal information: 步骤 3 中的图像 1,3 iPad Mini 6 Screen Replacement, Screen removal information: 步骤 3 中的图像 2,3 iPad Mini 6 Screen Replacement, Screen removal information: 步骤 3 中的图像 3,3
      • While you're waiting for the adhesive to loosen, note the following:
      • The areas at the top and bottom of the screen are sensitive to prying.
      • Don't insert a pick more than 3 mm to avoid damaging the screen.
      • There's a long circuit board attached to the screen that sits parallel to the left edge.
      • Don't insert a pick more than 1.5 mm to avoid damaging the circuit board.
      • The first two images are mirrored for demonstration purposes.
      询问修复机器人
      添加评论
    3. iPad Mini 6 Screen Replacement, Insert an opening pick: 步骤 4 中的图像 1,3 iPad Mini 6 Screen Replacement, Insert an opening pick: 步骤 4 中的图像 2,3 iPad Mini 6 Screen Replacement, Insert an opening pick: 步骤 4 中的图像 3,3
      • Once the screen is warm to touch, apply a suction handle to the bottom edge of the screen and as close to the edge as possible.
      • Lift the screen with the suction handle to create a small gap between the screen and the frame.
      • Insert an opening pick into the gap between the frame and the screen.
      • Don't insert the pick more than 1.5 mm to avoid damaging the circuit board.
      • Leave the opening pick in place to prevent the adhesive from resealing.
      询问修复机器人
      添加评论
    4. iPad Mini 6 Screen Replacement, Separate the bottom adhesive: 步骤 5 中的图像 1,3 iPad Mini 6 Screen Replacement, Separate the bottom adhesive: 步骤 5 中的图像 2,3 iPad Mini 6 Screen Replacement, Separate the bottom adhesive: 步骤 5 中的图像 3,3
      • Slide the pick along the bottom edge of the device towards the bottom-right corner.
      • Leave the pick in to prevent the adhesive from resealing.
      询问修复机器人
      添加评论
    5. iPad Mini 6 Screen Replacement, Heat the right edge: 步骤 6 中的图像 1,1
      • Apply a heated iOpener to the right edge of the device for 90 seconds to loosen the adhesive underneath.
      询问修复机器人
      添加评论
    6. iPad Mini 6 Screen Replacement, Separate the bottom-right corner adhesive: 步骤 7 中的图像 1,3 iPad Mini 6 Screen Replacement, Separate the bottom-right corner adhesive: 步骤 7 中的图像 2,3 iPad Mini 6 Screen Replacement, Separate the bottom-right corner adhesive: 步骤 7 中的图像 3,3
      • Rotate the opening pick around the bottom-right corner of the device.
      询问修复机器人
      添加评论
    7. iPad Mini 6 Screen Replacement, Separate the remaining adhesive: 步骤 8 中的图像 1,2 iPad Mini 6 Screen Replacement, Separate the remaining adhesive: 步骤 8 中的图像 2,2
      • Repeat the heating, slicing, and leaving opening picks for the remaining edges of the device.
      • When you slice near the front camera, don't insert the pick more than 1.5 mm to avoid damaging or smearing the camera.
      询问修复机器人
      添加评论
    8. iPad Mini 6 Screen Replacement, Reposition the screen: 步骤 9 中的图像 1,3 iPad Mini 6 Screen Replacement, Reposition the screen: 步骤 9 中的图像 2,3 iPad Mini 6 Screen Replacement, Reposition the screen: 步骤 9 中的图像 3,3
      • If there's still resistance around the edges of the screen, use an opening pick to cut the adhesive again.
      • Don't try to remove the screen all the way yet; it's still connected to the frame by a flex cable.
      • With the bottom of the device facing you, pull the right edge of the screen up and towards the left edge of the device.
      • Rest the screen upside down and parallel to the frame before continuing.
      • Don't twist the screen or move it too far away from the frame to avoid damaging the flex cable.
      询问修复机器人
      添加评论
    9. iPad Mini 6 Screen Replacement, Unfasten the display cable bracket: 步骤 10 中的图像 1,2 iPad Mini 6 Screen Replacement, Unfasten the display cable bracket: 步骤 10 中的图像 2,2
      • Use a Phillips #000 screwdriver to remove the five 1.2 mm-long screws securing the frame bracket to the frame.
      询问修复机器人
      添加评论
    10. iPad Mini 6 Screen Replacement, Remove the display cable bracket: 步骤 11 中的图像 1,2 iPad Mini 6 Screen Replacement, Remove the display cable bracket: 步骤 11 中的图像 2,2
      在这个步骤中使用的工具:
      • Use tweezers, or your fingers, to remove the display cable bracket from the frame.
      询问修复机器人
      添加评论
    11. iPad Mini 6 Screen Replacement, Disconnect the display: 步骤 12 中的图像 1,3 iPad Mini 6 Screen Replacement, Disconnect the display: 步骤 12 中的图像 2,3 iPad Mini 6 Screen Replacement, Disconnect the display: 步骤 12 中的图像 3,3
      • Use the flat end of a spudger to pry up and disconnect the display cable's two press connectors secured to the frame.
      询问修复机器人
      添加评论
    12. iPad Mini 6 Screen Replacement, Remove the screen: 步骤 13 中的图像 1,2 iPad Mini 6 Screen Replacement, Remove the screen: 步骤 13 中的图像 2,2
      • Remove the screen from the frame.
      询问修复机器人
      添加评论
    1. iPad Mini 6 Screen Replacement, Only the screen remains: 步骤 14 中的图像 1,1
      • You're now left with the screen separated from the frame.
      询问修复机器人
      添加评论
结论
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPad mini 6 Answers community for help.
取消:我没有完成这个指南。
22等其他人完成本指南。
Alex Diaz-Kokaisl
于01/16/22注册
247,590 声望
创作了1,203篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了83,908篇指南
3指南评论
Apple iPad Mini 6, 이전 세대보다 화면이 커지긴 했어도 필기용으로은 조금 별로..
그렇다고 Mini 에서 Pro 급의 초대형 화면을 바라기엔 좀 그렇고,,
Turtle - 回复 分享
El primer paso la foto esta mal...
sergiocb - 回复 分享
Are there any steps for assembling the screen, instead of only showing the assembly? And does the screen replacement come with adhesive strips, or do I need to order them seperately from another store? If so, how do I apply that?
Wikiredia - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 51
过去 7 天: 336
过去 30 天: 1,397
总计 54,780
