跳转到主内容
eufy RoboVac 11 Wheel and Wheel Motor Replacement
Kyleigh Hill
Kyleigh Hill2 其他贡献者
最后更新于 December 22, 2022
15分钟
中等
缺少的步骤
需要更多图片
不一致的图片
If your eufy RoboVac 11 is having trouble maneuvering throughout rooms or is immobile altogether, taking a look through this guide may be beneficial. This guide requires taking apart the device, keeping track of various parts, and some skill in replacing both the wheels and motors. However, because of how in depth this guide is, it will allow you to have access to the entire interior of the device. It is a perfect time to clean it thoroughly.
你所需要的
工具
  1. eufy RoboVac 11 Wheel and Wheel Motor Replacement, Front Cover and Motherboard: 步骤 1 中的图像 1,2 eufy RoboVac 11 Wheel and Wheel Motor Replacement, Front Cover and Motherboard: 步骤 1 中的图像 2,2
    • Remove the nine 10 mm screws with the Phillips #1 precision screwdriver.
    • Keep track of these screws. They are the same length as the interior screws but wider in diameter.
  2. eufy RoboVac 11 Wheel and Wheel Motor Replacement: 步骤 2 中的图像 1,2 eufy RoboVac 11 Wheel and Wheel Motor Replacement: 步骤 2 中的图像 2,2
    • Remove the six 7 mm screws on the bumper with the Phillips #1 screwdriver.
  3. eufy RoboVac 11 Wheel and Wheel Motor Replacement: 步骤 3 中的图像 1,3 eufy RoboVac 11 Wheel and Wheel Motor Replacement: 步骤 3 中的图像 2,3 eufy RoboVac 11 Wheel and Wheel Motor Replacement: 步骤 3 中的图像 3,3
    • Remove the top plate from the body of the device.
    • Unplug the bumper from the motherboard.
  4. eufy RoboVac 11 Wheel and Wheel Motor Replacement: 步骤 4 中的图像 1,2 eufy RoboVac 11 Wheel and Wheel Motor Replacement: 步骤 4 中的图像 2,2
    • Remove the three 10 mm motherboard screws with a Phillips #1 screwdriver.
    • Cleaning the motherboard and inside of the device outdoors with a compressed air cleaner will help the robot last longer.
  5. eufy RoboVac 11 Wheel and Wheel Motor Replacement: 步骤 5 中的图像 1,2 eufy RoboVac 11 Wheel and Wheel Motor Replacement: 步骤 5 中的图像 2,2
    • Unplug the cables from the motherboard.
  6. eufy RoboVac 11 Wheel and Wheel Motor Replacement, Rolling Brush: 步骤 6 中的图像 1,2 eufy RoboVac 11 Wheel and Wheel Motor Replacement, Rolling Brush: 步骤 6 中的图像 2,2
    • Remove the single 10 mm screw with the Phillips #1 screwdriver.
    • Remove the rolling brush.
  7. eufy RoboVac 11 Wheel and Wheel Motor Replacement, Wheel and Wheel Motor: 步骤 7 中的图像 1,3 eufy RoboVac 11 Wheel and Wheel Motor Replacement, Wheel and Wheel Motor: 步骤 7 中的图像 2,3 eufy RoboVac 11 Wheel and Wheel Motor Replacement, Wheel and Wheel Motor: 步骤 7 中的图像 3,3
    • Remove the wheels.
    • The removal of the two wheels is the same on both sides, but on the left side there is a motor in the way of the wheels.
    • Remove the single 10 mm screw with the Phillips #1 screwdriver and then pull upwards to remove the piece preventing removal.
  8. eufy RoboVac 11 Wheel and Wheel Motor Replacement: 步骤 8 中的图像 1,3 eufy RoboVac 11 Wheel and Wheel Motor Replacement: 步骤 8 中的图像 2,3 eufy RoboVac 11 Wheel and Wheel Motor Replacement: 步骤 8 中的图像 3,3
    • Remove the three 10 mm screws with the Phillips #1 screwdriver.
    • Remove motors.
    • The process for removing the left and right motors is the same.
结论
另外一个人完成了本指南。
Kyleigh Hill
于09/27/22注册
259 声望
创作了2篇指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 16
过去 30 天: 59
总计 1,698
