跳转到主内容
eufy RoboVac 11 Rolling Brush Replacement
Myles Mattinson
Myles Mattinson2 其他贡献者
最后更新于 December 22, 2022
10分钟
中等
缺少的步骤
需要更多图片
If your eufy RoboVac 11 rolling brush is getting stuck, isn't rotating, or having trouble picking up debris, looking through this guide may be beneficial. Replacing the rolling brush motor requires a little more attention to detail but is reasonably straightforward. With these steps, removal will be quick and easy. Removing the rolling brush before attempting to remove the motor is essential. Attempting to remove the motor without removing the brush may result in personal injury or damage to the device. Regular cleaning for the rolling brush will help its effectiveness in picking up debris.
你所需要的
工具
  1. eufy RoboVac 11 Rolling Brush Replacement, Front Cover and Motherboard: 步骤 1 中的图像 1,2 eufy RoboVac 11 Rolling Brush Replacement, Front Cover and Motherboard: 步骤 1 中的图像 2,2
    • Remove the nine 10 mm screws with the Phillips #1 precision screwdriver.
    • Keep track of these screws. They are the same length as the interior screws but wider in diameter.
  2. eufy RoboVac 11 Rolling Brush Replacement: 步骤 2 中的图像 1,2 eufy RoboVac 11 Rolling Brush Replacement: 步骤 2 中的图像 2,2
    • Remove the six 7 mm screws on the bumper with the Phillips #1 screwdriver.
  3. eufy RoboVac 11 Rolling Brush Replacement: 步骤 3 中的图像 1,3 eufy RoboVac 11 Rolling Brush Replacement: 步骤 3 中的图像 2,3 eufy RoboVac 11 Rolling Brush Replacement: 步骤 3 中的图像 3,3
    • Remove the top plate from the body of the device.
    • Unplug the bumper from the motherboard.
  4. eufy RoboVac 11 Rolling Brush Replacement: 步骤 4 中的图像 1,2 eufy RoboVac 11 Rolling Brush Replacement: 步骤 4 中的图像 2,2
    • Remove the three 10 mm motherboard screws with a Phillips #1 screwdriver.
    • Cleaning the motherboard and inside of the device outdoors with a compressed air cleaner will help the robot last longer.
  5. eufy RoboVac 11 Rolling Brush Replacement: 步骤 5 中的图像 1,2 eufy RoboVac 11 Rolling Brush Replacement: 步骤 5 中的图像 2,2
    • Unplug the cables from the motherboard.
  6. eufy RoboVac 11 Rolling Brush Replacement, Rolling Brush: 步骤 6 中的图像 1,2 eufy RoboVac 11 Rolling Brush Replacement, Rolling Brush: 步骤 6 中的图像 2,2
    • Remove the single 10 mm screw with the Phillips #1 screwdriver.
    • Remove the rolling brush.
结论
Myles Mattinson
于09/28/22注册
316 声望
创作了4篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 30
总计 1,671
