跳转到主内容
ZTE Tempo Front Camera Replacement
Dela Mohammed
Dela Mohammed4 其他贡献者
最后更新于 October 3, 2021
20分钟
简单
需要更好的图片
更好的介绍
If the camera is showing a black screen or the camera does not take a picture.
你所需要的
工具
  1. ZTE Tempo Front Camera Replacement, Front Camera: 步骤 1 中的图像 1,3 ZTE Tempo Front Camera Replacement, Front Camera: 步骤 1 中的图像 2,3 ZTE Tempo Front Camera Replacement, Front Camera: 步骤 1 中的图像 3,3
    • Pry open the back case to get to the back cover.
    • Remove eight 5mm screws with a PH0 screw.
    • Pry open the back cover with a plastic opening tool.
    • Slide the plastic opening tool alongside the side seam twisting your hand forcefully to open the back cover.
    • Note: Pry open by finding an edge and forcing it open with the plastic opening tool.
  2. ZTE Tempo Front Camera Replacement: 步骤 2 中的图像 1,3 ZTE Tempo Front Camera Replacement: 步骤 2 中的图像 2,3 ZTE Tempo Front Camera Replacement: 步骤 2 中的图像 3,3
    • Use a plastic opening tool to lift the press-fit connector up and disconnect the battery ribbon cable.
    • Lift the battery up and remove it from the phone.
  3. ZTE Tempo Front Camera Replacement: 步骤 3 中的图像 1,2 ZTE Tempo Front Camera Replacement: 步骤 3 中的图像 2,2
    • Use a plastic opening tool to lift the press-fit connector up and disconnect the front camera ribbon cable.
    • Lift the front camera out of the phone.
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 158
