跳转到主内容
ZTE Speed Motherboard Replacement
Garrett Barry
Garrett Barry3 其他贡献者
最后更新于 October 1, 2021
2分钟
中等
As it controls the whole phone, knowing how to remove the motherboard of the ZTE Speed is important.
你所需要的
工具
  1. ZTE Speed Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,2 ZTE Speed Motherboard Replacement, Motherboard: 步骤 1 中的图像 2,2
    • Pull off back cover at bottom right corner.
  2. ZTE Speed Motherboard Replacement: 步骤 2 中的图像 1,2 ZTE Speed Motherboard Replacement: 步骤 2 中的图像 2,2
    • Remove the seven 3.175mm Phillips head screws from the inner back located at the top, upper-middle-right, middle-right, lower-right, and bottom.
  3. ZTE Speed Motherboard Replacement: 步骤 3 中的图像 1,2 ZTE Speed Motherboard Replacement: 步骤 3 中的图像 2,2
    • With the plastic opening tool the spudger, gently pry off the inner back.
    • Be careful not to pry it off too hard, as it is just a plastic covering.
  4. ZTE Speed Motherboard Replacement: 步骤 4 中的图像 1,1
    • Remove the one 2.381mm Phillips head screw from the motherboard located in the upper-middle part of the phone next to the bottom left corner of the back camera.
  5. ZTE Speed Motherboard Replacement: 步骤 5 中的图像 1,3 ZTE Speed Motherboard Replacement: 步骤 5 中的图像 2,3 ZTE Speed Motherboard Replacement: 步骤 5 中的图像 3,3
    • Using the spudger, gently pry up all ZIF connectors
    • ZIF connectors have a tiny tab that needs to be flipped up in order to safely remove the cable
    • Using same spudger, gently pry up the orange flat top connector
  6. ZTE Speed Motherboard Replacement: 步骤 6 中的图像 1,2 ZTE Speed Motherboard Replacement: 步骤 6 中的图像 2,2
    • Carefully take off motherboard.
结论
另外一个人完成了本指南。
Garrett Barry
于03/04/16注册
722 声望
创作了5篇指南
团队
UMass Dartmouth, Team 6-3, Bhusal Spring 2016 UMass Dartmouth, Team 6-3, Bhusal Spring 2016 的会员
UMASSD-BHUSAL-S16S6G3
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 727
