跳转到主内容
加入维修社区 - 创建账户
ZTE Prestige 2 Back Camera Replacement
你所需要的
    1. ZTE Prestige 2 Back Camera Replacement, Battery: 步骤 1 中的图像 1,3 ZTE Prestige 2 Back Camera Replacement, Battery: 步骤 1 中的图像 2,3 ZTE Prestige 2 Back Camera Replacement, Battery: 步骤 1 中的图像 3,3
      • Use the iFixit opening tool to open up the device by wedging the tool under the back case and popping it open.
      询问修复机器人
      添加评论
    2. ZTE Prestige 2 Back Camera Replacement: 步骤 2 中的图像 1,2 ZTE Prestige 2 Back Camera Replacement: 步骤 2 中的图像 2,2
      • Remove the battery.
      询问修复机器人
      添加评论
    1. ZTE Prestige 2 Back Camera Replacement, Back Panel: 步骤 3 中的图像 1,3 ZTE Prestige 2 Back Camera Replacement, Back Panel: 步骤 3 中的图像 2,3 ZTE Prestige 2 Back Camera Replacement, Back Panel: 步骤 3 中的图像 3,3
      • Use a Phillips #00 screwdriver to unscrew all 12 of the 3 mm Phillips screws located along the edges of the device’s back panel, as well as the blue 3mm Phillips screw labeled “ZTE” located towards the top right.
      询问修复机器人
      添加评论
    2. ZTE Prestige 2 Back Camera Replacement: 步骤 4 中的图像 1,3 ZTE Prestige 2 Back Camera Replacement: 步骤 4 中的图像 2,3 ZTE Prestige 2 Back Camera Replacement: 步骤 4 中的图像 3,3
      • Then use the iFixit opening tool and wedge it under the grey back panel and pop it off.
      • There will be a lot of resistance, apply adequate pressure.
      询问修复机器人
      添加评论
    1. ZTE Prestige 2 Back Camera Replacement, Back Camera: 步骤 5 中的图像 1,3 ZTE Prestige 2 Back Camera Replacement, Back Camera: 步骤 5 中的图像 2,3 ZTE Prestige 2 Back Camera Replacement, Back Camera: 步骤 5 中的图像 3,3
      • Use the iFixit opening pick and wedge it under the press fit connector beside the camera located at the top center of the device to pop it off.
      • Remove the camera.
      • The camera cable near the press fit connector is delicate, ripping it will cause permanent damage.
      • The base of the camera may be glued down which may lead to accidental ripping during removal. Use the flat end of a metal spudger to pry it up if necessary.
      添加评论
结论
取消:我没有完成这个指南。
Maria Stock
于01/31/20注册
524 声望
创作了5篇指南
团队
UW Stout, Team S1-G4, Schneider-Bateman Spring 2020 UW Stout, Team S1-G4, Schneider-Bateman Spring 2020 的会员
UWSTOUT-SCHNEIDER-BATEMAN-S20S1G4
3 名成员
创作了42篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 12
过去 30 天: 34
总计 515
