跳转到主内容
ZTE Blade Spark Screen Replacement
Solomon Barket
Solomon Barket2 其他贡献者
最后更新于 October 10, 2024
15分钟
中等
A step-by-step guide on how to replace the screen on a ZTE Blade Spark smartphone.
This guide is useful if the screen is cracked, has dead pixels, or is not displaying anything.
Please use caution and the necessary PPE if working with cracked screen glass.
你所需要的
工具
查看更多...
  1. ZTE Blade Spark Screen Replacement, Screen: 步骤 1 中的图像 1,1
    • Place phone screen side down on a flat surface.
  2. ZTE Blade Spark Screen Replacement: 步骤 2 中的图像 1,2 ZTE Blade Spark Screen Replacement: 步骤 2 中的图像 2,2
    • Take an opening tool, and insert it between the phone's backplate and chassis.
    • Work the tool all the way around perimeter of the phone until the backplate is free.
  3. ZTE Blade Spark Screen Replacement: 步骤 3 中的图像 1,1
    • Use a Phillips #00 screwdriver to carefully remove all fifteen 3.0 mm screws.
  4. ZTE Blade Spark Screen Replacement: 步骤 4 中的图像 1,1
    • Remove the middle plate that was unscrewed from the previous step.
    • At this stage you should have 3 separate parts as shown.
    • For the next step you will be working on the middle part in this picture.
  5. ZTE Blade Spark Screen Replacement: 步骤 5 中的图像 1,1
    • Take black covering off of battery.
  6. ZTE Blade Spark Screen Replacement: 步骤 6 中的图像 1,2 ZTE Blade Spark Screen Replacement: 步骤 6 中的图像 2,2
    在这个步骤中使用的工具:
    • Unclip fastener located in the red box. Blunt end tweezers are recommended for this process.
  7. ZTE Blade Spark Screen Replacement: 步骤 7 中的图像 1,2 ZTE Blade Spark Screen Replacement: 步骤 7 中的图像 2,2
    • Remove battery so you are left with the base of the phone, the battery, and the battery cover separated.
  8. ZTE Blade Spark Screen Replacement: 步骤 8 中的图像 1,1
    • Remove the 4mm screws in the 2 red circles shown with the Phillips #00 screwdriver.
  9. ZTE Blade Spark Screen Replacement: 步骤 9 中的图像 1,1
    • Heat all 4 sides of the piece with the iOpener to loosen adhesive.
  10. ZTE Blade Spark Screen Replacement: 步骤 10 中的图像 1,2 ZTE Blade Spark Screen Replacement: 步骤 10 中的图像 2,2
    • Now remove the screen from it's base using the opening tool.
结论
Swap your old screen with your new screen. To reassemble your device with a new screen, follow these instructions in reverse order.
Solomon Barket
于03/27/23注册
181 声望
撰写一个指南
团队
IUPUI, Team 1-3, Harley Spring 2023 IUPUI, Team 1-3, Harley Spring 2023 的会员
IUPUI-HARLEY-S23S1G3
3 名成员
创作了4篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 24
总计 245
