跳转到主内容
ZTE Blade Spark Rear-Facing Camera
Hung Vu
Hung Vu4 其他贡献者
最后更新于 March 28, 2023
10 - 15 分钟
中等
动态照片拍摄
需要更多图片
缺少的步骤
详尽分析
Follow this guide to disassemble the ZTE Blade Spark device and replace the rear-facing camera.
  1. ZTE Blade Spark Rear-Facing Camera, ZTE Blade Spark Rear-Facing Camera: 步骤 1 中的图像 1,1
    • First, apply heat evenly on the back cover using a heat sack to soften the adhesive.
  2. ZTE Blade Spark Rear-Facing Camera: 步骤 2 中的图像 1,1
    • Now, carefully remove the back cover.
  3. ZTE Blade Spark Rear-Facing Camera: 步骤 3 中的图像 1,1
    • Once opened, Locate and remove all exposed screws using a Phillips-Head screwdriver and set them aside.
  4. ZTE Blade Spark Rear-Facing Camera: 步骤 4 中的图像 1,1
    • To remove the inner white panel/cover, use a plastic opening tool to loosen from each side.
  5. ZTE Blade Spark Rear-Facing Camera: 步骤 5 中的图像 1,1
    • After removing the white plastic panel, you should see a black metal battery cover.
    • To remove the metal battery cover, remove the screws from the panel using a Phillips screwdriver if you have not yet done so.
  6. ZTE Blade Spark Rear-Facing Camera: 步骤 6 中的图像 1,1
    • Then, simple lift to remove the metal battery cover.
  7. ZTE Blade Spark Rear-Facing Camera: 步骤 7 中的图像 1,1
    • You have reached the Fingerprint Scanner, the device Battery, and Front Facing Camera.
  8. ZTE Blade Spark Rear-Facing Camera: 步骤 8 中的图像 1,3 ZTE Blade Spark Rear-Facing Camera: 步骤 8 中的图像 2,3 ZTE Blade Spark Rear-Facing Camera: 步骤 8 中的图像 3,3
    • Proceeding with disassembly, next up is the top chipset which the Rear Facing Camera is attached to.
    • To detach the chipset and reach the Rear Camera, locate and disconnect five power connectors surrounding the top chipset (as shown in images).
  9. ZTE Blade Spark Rear-Facing Camera: 步骤 9 中的图像 1,1
    • Once you have the power connectors disconnected from the top chipset, use a Phillips screwdriver to remove the final screw located at the very top of the chipset (as shown in image).
  10. ZTE Blade Spark Rear-Facing Camera: 步骤 10 中的图像 1,1
    • Then, simply lift chipset from top and detach from the device frame.
  11. ZTE Blade Spark Rear-Facing Camera: 步骤 11 中的图像 1,1
    • You have now reached the final replacement component of the device, the Rear Facing Camera!
    • For step-by-step instructions on replacing any of the device components covered throughout the disassembly process, check out our ZTE Blade Spark Replacement guides.
结论
2等其他人完成本指南。
Hung Vu
于01/24/18注册
632 声望
撰写一个指南
团队
Gateway, Team S1-G6, Johnson Spring 2018 Gateway, Team S1-G6, Johnson Spring 2018 的会员
GCC-JOHNSON-S18S1G6
2 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 17
总计 2,442
