跳转到主内容
加入维修社区 - 创建账户
Xbox Series S Fan Replacement
你所需要的
  1. Xbox Series S Fan Replacement, Peel off the sticker coverings: 步骤 1 中的图像 1,3 Xbox Series S Fan Replacement, Peel off the sticker coverings: 步骤 1 中的图像 2,3 Xbox Series S Fan Replacement, Peel off the sticker coverings: 步骤 1 中的图像 3,3
    在这个步骤中使用的工具:
    • Before you start this guide, turn off the Xbox and unplug any cables from it.
    • Use tweezers to peel off the two white screw covers located on the bottom corners of the back panel.
    添加评论
  2. Xbox Series S Fan Replacement, Remove the back panel screws: 步骤 2 中的图像 1,1
    在这个步骤中使用的工具:
    Magnetic Project Mat
    $19.95
    • Use a T8 Torx driver to remove the two 10 mm-long screws securing the back panel to the bottom panel.
    询问修复机器人
    添加评论
  3. Xbox Series S Fan Replacement, Remove the bottom panel: 步骤 3 中的图像 1,3 Xbox Series S Fan Replacement, Remove the bottom panel: 步骤 3 中的图像 2,3 Xbox Series S Fan Replacement, Remove the bottom panel: 步骤 3 中的图像 3,3
    • Slide the bottom panel horizontally toward the back of the console until it comes to a stop.
    • This slides the clips out of the slots on the plastic case.
    • Lift straight up and remove the bottom panel from the plastic case.
    询问修复机器人
    添加评论
  4. Xbox Series S Fan Replacement, Remove the plastic case screws: 步骤 4 中的图像 1,1
    • Use a T10 Torx driver to remove the seven 51 mm-long screws securing the chassis to the plastic case.
    询问修复机器人
    添加评论
  5. Xbox Series S Fan Replacement, Remove the plastic case: 步骤 5 中的图像 1,3 Xbox Series S Fan Replacement, Remove the plastic case: 步骤 5 中的图像 2,3 Xbox Series S Fan Replacement, Remove the plastic case: 步骤 5 中的图像 3,3
    • With the bottom of the Xbox facing you, pull the two bottom-rear corners of the plastic case away from each other.
    • As you pull the corners apart, slide the back panel towards the bottom of the device. This releases the back panel from the plastic case.
    • The back panel should now settle on top of the clips on the back of the plastic case.
    • The back panel is permanently attached to the aluminum chassis.
    • Do not attempt to fully remove the chassis from the plastic case with this technique. You may risk breaking your case.
    询问修复机器人
    添加评论
  6. Xbox Series S Fan Replacement: 步骤 6 中的图像 1,3 Xbox Series S Fan Replacement: 步骤 6 中的图像 2,3 Xbox Series S Fan Replacement: 步骤 6 中的图像 3,3
    • Pull the bottom-left corner away from the chassis while swinging the chassis away from the plastic case.
    • You may need to lift the chassis to free it from the clips on the bottom-front of the plastic case during this process.
    • Remove the plastic case from the chassis.
    询问修复机器人
    添加评论
  7. Xbox Series S Fan Replacement, Remove the power supply screws: 步骤 7 中的图像 1,1
    • Use a T10 Torx driver to remove the seven 11.3 mm-long screws securing the power supply to the chassis.
    添加评论
  8. Xbox Series S Fan Replacement, Remove the upper chassis: 步骤 8 中的图像 1,2 Xbox Series S Fan Replacement, Remove the upper chassis: 步骤 8 中的图像 2,2
    • Flip the device over.
    • Lift the upper chassis straight up to remove it.
    添加评论
  9. Xbox Series S Fan Replacement, Remove the power supply: 步骤 9 中的图像 1,3 Xbox Series S Fan Replacement, Remove the power supply: 步骤 9 中的图像 2,3 Xbox Series S Fan Replacement, Remove the power supply: 步骤 9 中的图像 3,3
    • Lift the power supply straight up to disconnect it from the motherboard.
    • Remove the power supply.
    添加评论
  10. Xbox Series S Fan Replacement, Remove the fan screws: 步骤 10 中的图像 1,1
    • Use a T10 Torx driver to remove the two 11.3 mm-long screws securing the fan to the chassis.
    询问修复机器人
    添加评论
  11. Xbox Series S Fan Replacement, Disconnect the fan: 步骤 11 中的图像 1,2 Xbox Series S Fan Replacement, Disconnect the fan: 步骤 11 中的图像 2,2
    • Take care when flipping the chassis over because the fan is now loose.
    • Use your fingers to pull and disconnect the fan connector from its motherboard socket.
    • Take care not to pull on the wires when disconnecting the fan to prevent breaking the connector.
    • This connector may be difficult to remove. A good method to remove it is to shimmy the connector up and out of its socket with a spudger.
    • You may be able to remove this connector without removing the power supply with a pair of needle-nose pliers.
    添加评论
  12. Xbox Series S Fan Replacement, Remove the fan: 步骤 12 中的图像 1,2 Xbox Series S Fan Replacement, Remove the fan: 步骤 12 中的图像 2,2
    • Lift the fan straight up to remove it from the motherboard.
    添加评论
结论
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
取消:我没有完成这个指南。
37等其他人完成本指南。
Robert Boyd
于02/01/21注册
33,453 声望
创作了94篇指南
2指南评论
what kind of pin connector does the fan use? i want to see if it’s possible to attach a fan splitter y cable.
Sir Yeeks - 回复 分享
Hi wondering if I’m able to switch out the fan to another fan like a noctua fan but I don’t know what fab size?
bp.guevara87 - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 36
过去 7 天: 245
过去 30 天: 1,090
总计 43,552
