跳转到主内容
加入维修社区 - 创建账户
Xbox One Elite Controller (Model 1698) Rumble Motor Replacement
你所需要的
  1. Xbox One Elite Controller (Model 1698) Rumble Motor Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn over the controller so that the buttons face down.
    • Be gentle when removing the cover so you do not break the small plastic tabs holding the cover to the controller.
    • Remove the battery cover carefully by sliding the cover up in the direction of the arrow.
    询问修复机器人
    添加评论
  2. Xbox One Elite Controller (Model 1698) Rumble Motor Replacement: 步骤 2 中的图像 1,2 Xbox One Elite Controller (Model 1698) Rumble Motor Replacement: 步骤 2 中的图像 2,2
    • Remove the two batteries AA batteries by lifting them from one end and pulling them out.
    询问修复机器人
    添加评论
  3. Xbox One Elite Controller (Model 1698) Rumble Motor Replacement, Rumble Motor: 步骤 3 中的图像 1,3 Xbox One Elite Controller (Model 1698) Rumble Motor Replacement, Rumble Motor: 步骤 3 中的图像 2,3 Xbox One Elite Controller (Model 1698) Rumble Motor Replacement, Rumble Motor: 步骤 3 中的图像 3,3
    • Be careful not to break the plastic tabs, that hold each grip cover to the back of the controller.
    • Remove each grip by inserting the plastic opening tool near the top of the controller.
    • Guide the plastic opening tool along the entire seam and gently separate the grip from the controller in a prying motion as you go.
    添加评论
  4. Xbox One Elite Controller (Model 1698) Rumble Motor Replacement: 步骤 4 中的图像 1,2 Xbox One Elite Controller (Model 1698) Rumble Motor Replacement: 步骤 4 中的图像 2,2
    • Remove the five 2.3 mm screws with the TR8 Torx Security screwdriver.
    • Four of the screws are located at the bottom tip of each grip and at the top of each grip, near the triggers of the controller.
    • The last screw is located in the center of the battery tray beneath a sticker.
    • Use a TR8 Torx Security Screwdriver to puncture the sticker and remove the final screw.
    添加评论
  5. Xbox One Elite Controller (Model 1698) Rumble Motor Replacement: 步骤 5 中的图像 1,3 Xbox One Elite Controller (Model 1698) Rumble Motor Replacement: 步骤 5 中的图像 2,3 Xbox One Elite Controller (Model 1698) Rumble Motor Replacement: 步骤 5 中的图像 3,3
    • Flip the controller so that the buttons are face up to prevent the vibration motors from falling out of the controller.
    • Remove the D-pad by lifting the bottom and pulling it up.
    • Remove the entire plastic faceplate by pulling it up gently.
    • Remove the thumbsticks by pulling them off from the top.
    添加评论
  6. Xbox One Elite Controller (Model 1698) Rumble Motor Replacement: 步骤 6 中的图像 1,2 Xbox One Elite Controller (Model 1698) Rumble Motor Replacement: 步骤 6 中的图像 2,2
    • Remove the small black mode switch from the front of the controller.
    • The backplate gets a little stuck on the port at the bottom so you may have to use a prying motion to remove.
    • Be careful in the next step when pulling the main assembly apart from the backplate. There is a ribbon cable that connects the two parts that must stay in tact.
    • Remove the backplate from the main assembly by pulling them apart.
    添加评论
  7. Xbox One Elite Controller (Model 1698) Rumble Motor Replacement: 步骤 7 中的图像 1,1
    在这个步骤中使用的工具:
    • The small ribbon cable connects the back cover to the internals of the controller. To remove the cable, lift the black lever on the opposite side of the connector from the cable.
    • Use tweezers to unplug the ribbon cable on the side closest to the back cover by pulling the cable parallel to the surface of the circuit board.
    添加评论
  8. Xbox One Elite Controller (Model 1698) Rumble Motor Replacement: 步骤 8 中的图像 1,2 Xbox One Elite Controller (Model 1698) Rumble Motor Replacement: 步骤 8 中的图像 2,2
    • Mark each motor according to where it attaches. The rumble motors are different so they will not work if you switch them.
    • Take note of where the red and black motor wires attach because they should be reattached in the same order.
    • Turn over the controller so that the thumbsticks are facing down.
    • Use tweezers and a soldering iron (Soldering Iron Guide) to remove the black and red wires from the motherboard.
    • This will release the rumble motor from the controller assembly.
    添加评论
结论
取消:我没有完成这个指南。
10等其他人完成本指南。
Cara
于09/25/17注册
1,648 声望
创作了6篇指南
团队
Cal Poly, Team S18-G4, Forte Fall 2017 Cal Poly, Team S18-G4, Forte Fall 2017 的会员
CPSU-FORTE-F17S18G4
4 名成员
创作了24篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 17
过去 30 天: 88
总计 12,422
